[mapguide-users] Integrating remote layers into existing repository
Andy Morsell amorsell at spatialgis.com
Fri May 12 12:08:01 EDT 2006
The only way this could be done would be to do some programming to first
upload their Shape files as resources into the repository and then you could
do whatever you need to to display layers from it.  Some users here are
working with publishing MapGuide Open Source data as WMS layers so perhaps
your users could use their client interface (such as ArcView) to view both
their local Shape files and the MGOS layers from WMS?
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
Sent: Thursday, May 11, 2006 11:09 PM
Subject: [mapguide-users] Integrating remote layers into existing repository
Would it be possible to integrate a shp file which is on a client's machine
in the repository which is hosted on a server.
E.g. There is a server running MGOS and having a respository. This server
has an app which shows the map from the repository and allows many other
functionalities to the user. Now there are some clients who have their own
set of .shp files on their local hard disk.
Is it possible to integrate these layers at run time and display them as
part of the map for that user only ?
- Kalpesh
View this message in context:
http://www.nabble.com/Integrating-remote-layers-into-existing-repository-t16
05641.html#a4353417
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
