[mapguide-users] shp or sdf advantages/disadvanatges
Traian Stanev
traian.stanev at autodesk.com
Thu May 18 11:30:48 EDT 2006
Right, linking the SDF to an external DBF would kill performance, but luckily it's not needed since all the data ends up in the SDF...
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thu 5/18/2006 11:09 AM
Cc:
Subject: RE: [mapguide-users] shp or sdf advantages/disadvanatges
I have also found that for larger Shape files, converting to SDF at load time results in much better performance. For large parcel datasets, I also generalize the data using FME. Since SDF+ contains all of the attribute information from the source Shape files DBF, you would probably want to just use that for tooltips, etc. rather than linking to the DBF file. FME from Safe Software also will soon be including SDF+ support in their product. The current beta version downloadable from their web site supports SDF+
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: shailesh [mailto:shailesh at simplexindia.com]
Sent: Wednesday, May 17, 2006 11:38 PM
Subject: [mapguide-users] shp or sdf advantages/disadvanatges
hi
I am currently using shp files for data resources and some of the data is above 80 mb
I think it makes the map very slow to load
does converting into sdf or another format help it load faster.
what are advantages /disadvantages .in terms of laoding speed,attribute table data etc
can i use the convert to sdf option in studio or a there any other specialized toosl for doing it.
if converted to sdf can i still use the dbf assoicated with shp for tooltips and attribute data
-shailesh
--------------------------------------------------------------------- To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060518/cf1becde/attachment.bin
More information about the Mapguide-users
