[mapguide-users] Win2003 fcgi Install Issue and Solution
gis1stop
gis1stop at gmail.com
Thu May 18 17:02:12 EDT 2006
Andy,
Thank you so much for sharing this. It is really helpful. By following your
idea, I also found:
Alternatively, you can also use the short path
"c:\PROGRA~1\MAPGUI~1\WEBSER~1\www\mapagent\ISAPI_~1.dll" as the required
file path for mapagent extension named in IIS Manager>>Web Service
Extensions folder.
As long as the paths for the mapagent Web Service Extension and for the
.fcgi extension in mapagent virtual directory in IIS are identical, it
should work.
Frank
View this message in context: http://www.nabble.com/Win2003-fcgi-Install-Issue-and-Solution-t1414988.html#a4458793
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users
