[mapguide-users] Select underlying objects
    Willem Schwarte
    willem at giskit.nl
    Tue May 23 09:39:48 EDT 2006
Do you mean a 'redline' rectangle? Could you point me out in the right
direction where to look for this in the webApi manual ? or do you might
have a short sample code of this?
Thanks...
Willem
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: dinsdag 23 mei 2006 15:23
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Select underlying objects
Create a very small rectangle (1 pixel wide) on the place where the
mouse was clicked and select with that rectangle.
Traian
Sent: Tuesday, May 23, 2006 9:16 AM
Subject: [mapguide-users] Select underlying objects
Is it possible to select all object that are under point clicked by a
single click? (so I do not mean selecting with a window)
With a selection with a window all layers are selected, but I want to do
this with just 1 click. E.g. 4 layers with the same geometry (parcels)
from which I need to get the properties.
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060523/872e4ff3/attachment.html
More information about the Mapguide-users
