[mapguide-users] Select underlying objects
Traian Stanev traian.stanev at autodesk.com
Tue May 23 09:22:42 EDT 2006
Create a very small rectangle (1 pixel wide) on the place where the
mouse was clicked and select with that rectangle.
Traian
  _____
Sent: Tuesday, May 23, 2006 9:16 AM
Subject: [mapguide-users] Select underlying objects
Is it possible to select all object that are under point clicked by a
single click? (so I do not mean selecting with a window)
With a selection with a window all layers are selected, but I want to do
this with just 1 click. E.g. 4 layers with the same geometry (parcels)
from which I need to get the properties.
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060523/61d97b8b/attachment.html
More information about the Mapguide-users mailing list
