[mapguide-users] Webstudio upload feature source?
Zak James zak4ms at gmail.com
Thu Nov 2 09:45:13 EST 2006
Tim,
During development, we tested the upload facility only with the
default apache web server so IIS may be involved in your problems. Can
you verify that the sdf file is present in the repository after
upload?
zak
On 11/1/06, METRO3 <twiebe at cityofwinkler.ca> wrote:
> It appears now that I can upload a datasource. I had to reinstall the server
> and extensions 1.0.2.
> However, even though I can upload the data,  when I try to create a layer
> from the uploaded sdf data. I am unable to select the featureclass or
> geometry to setup the layer.
> Is there criteria for creating sdf3? Should I consider shapefiles?
> I am creating a my sdf3 in Map 2007 my projection is NAD83 UTM.
> Using IIS5 for the server.
> THanks
> Tim
> Paul Spencer-2 wrote:
> > Tim,
> > there were some problems with the original implementation of the
> > upload facility in webstudio.  These were fixed recently in the trunk
> > but I don't know if those fixes made it into 1.0.2 release.
> > Can you let us know a bit about your configuration (server, web
> > server, version) and any error messages you are getting?
> > Cheers
> > Paul
> > On 31-Oct-06, at 3:51 PM, Tim Wiebe wrote:
> >> I am new to working with mgos, but can someone tell me why I can't
> >> upload my own sdf3 or shp through webstudio?
> >> Am I missing something obvious?
> >> Thanks
> >> Tim
> > |Paul Spencer                          pspencer at dmsolutions.ca    |
> > |Chief Technology Officer                                         |
> > |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail: users-help at mapguide.osgeo.org
> View this message in context: http://www.nabble.com/Webstudio-upload-feature-source--tf2548311.html#a7116223
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
Zak James
Applications and Software Development
DM Solutions Group Inc.
More information about the Mapguide-users mailing list
