[mapguide-users] Properties pane not displaying Web API generated selection properties [No Viruses detected]
Andy Morsell amorsell at spatialgis.com
Mon Nov 6 11:32:16 EST 2006
I have had the same problem for quite awhile and have come to ignore it as
"just the way it is".  I hope that there is a solution too.  It definitely
would be a desirable feature for the properties of the programmatically
selected object to display in the properties pane.
Andy
-----Original Message-----
From: Tom Chadwin [mailto:tom.chadwin at nnpa.org.uk]
Sent: Monday, November 06, 2006 4:12 AM
Subject: RE: [mapguide-users] Properties pane not displaying Web API
Hi Bill
Thanks for the reply. I have various properties checked to display for this
layer in MG Studio. When I use the mouse in my application to click on a
feature, those properties do indeed display. The problem only occurs when I
create a selection programmatically and send it to the map. The feature is
highlighted on the map, but the properties pane does not show the
properties.
I am wondering whether the problem is that I am connecting to the feature
source to make the selection, rather than the instance of the feature source
which is used in the layer on the map. Could that be the problem? If so, how
can I create a selection on an existing displayed layer on the map?
Any ideas?
Thanks
Tom
Tom Chadwin
ICT & Web Development Officer
Telephone: 01434 611530
Mobile:
Fax: 01434 611677
Email: tom.chadwin at nnpa.org.uk
Web : www.Northumberland-national-park.org.uk
<http://www.Northumberland-national-park.org.uk>
<http://www.northumberland-national-park.org.uk/>
____________________________________________________________________________
IMPORTANT NOTICE - Disclaimer - November 6, 2006 - REF
Email-200611-00041249.
If you have received this e-mail in error or wish to read our e-mail
disclaimer statement and monitoring policy, please refer to the statement
below or contact the sender.
This communication is from Northumberland National Park Authority (NNPA).The
Authority's head office and principal place of business is Eastburn, South
Park, Hexham, Northumberland, NE46 1BS, United Kingdom.This communication
and any attachments contain information which is confidential and may also
be privileged. It is for the exclusive use of users at mapguide.osgeo.org. If
you are not the intended recipient(s) please note that any form of
disclosure, distribution, copying or use of this communication or the
information in it or in any attachments is strictly prohibited and may be
unlawful. If you have received this communication in error, please return it
with the title "received in error" to "it.security at nnpa.org.uk" then delete
the email and destroy any copies of it.
E-mail communications cannot be guaranteed to be secure or error free, as
information could be intercepted, corrupted, amended, lost, destroyed,
arrive late or incomplete, or contain viruses. We do not accept liability
for any such matters or their consequences. Anyone who communicates with us
by e-mail is taken to accept the risks in doing so.
Any views or opinions presented are solely those of the author and do not
necessarily represent those of NNPA.Contractors or potential contractors are
reminded that a formal Order or Contract is needed for NNPA to be bound by
any offer or acceptance of terms for the supply of goods or services
Although this email and any attachments are believed to be free of any virus
or other defects which might affect any computer or IT system into which
they are received, no responsibility is accepted by the NNPA for any loss or
damage arising in any way from the receipt or use thereof. Computer systems
of this Authority may be monitored and communications carried out on them
recorded, to secure the effective operation of the system and for other
lawful purposes.
From: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Sent: 06 November 2006 11:16
Tom,
The LayerDefintion XML file needs to explicitly list the name of each
property that you want to display in the properties pane (under the
PropertyMapping element).  If you are using MapGuide Studio, use the
"Feature Data Setup" portion of the Layer Editor UI and check the checkboxes
in the "Properties displayed in the Viewer" list.
Bill
Sent: Monday, November 06, 2006 4:30 AM
> I am generating a selection in the Task pane, and then passing that
> selection to the Map frame and zooming the Map frame to the selection.
> The selection seems to be working, since the point turns blue on the
> map, and the status bar says 1 object selected. However, that
> feature's properties are not being displayed in the Properties pane.
> The message "None Selected" disappears, and the Name and Value column
> headings appear, but with no values listed below them.
> Is there something else I should be doing to get the list of
> properties to display? If I manually click on the feature, the
> properties display in the Properties pane correctly.
Can anyone help with this?
Thanks
Tom
Tom Chadwin
Mobile:
Fax: 01434 611677
____
Email-200611-00041076.
lawful purposes.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
