[mapguide-users] RE: Buffer Tool
Traian Stanev
traian.stanev at autodesk.com
Tue Nov 7 09:33:38 EST 2006
What coordinate is your map using? Is it in degrees?
-----Original Message-----
Sent: Tuesday, November 07, 2006 4:15 AM
Subject: [mapguide-users] RE: Buffer Tool
What is the solution to that ?
Walt Welton-Lair wrote:
> The buffer engine sometimes has trouble with certain polygons,
> especially when buffering in the context of a coordinate system. That
> can lead to the exception you're seeing.
> From: kalpesh [mailto:kalpesh at pie-solution.com]
> Sent: Tuesday, November 07, 2006 9:15 AM
> Subject: [mapguide-users] Buffer Tool
> In our maps, the built in buffer tools is creating a buffer only for
> points and not for polygons based layers. It just says 'An
> unclassified exception has occurred' and does not create a buffer.
> Any ideas why this happens ?
> http://www.nabble.com/Buffer-Tool-tf2587309.html#a7214190
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/Buffer-Tool-tf2587309.html#a7214901
More information about the Mapguide-users
