[mapguide-users] DWF files and Hyperlinks
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Nov 8 16:26:01 EST 2006
In your weblayout, try changing the hyperlink target to something other
than "Task pane". That might help.
Also make sure you're not inadvertently using relative hyperlinks. Make
sure they're prefixed with "http://" if they're external links.
_____
Sent: Wednesday, November 08, 2006 10:04 PM
Subject: [mapguide-users] DWF files and Hyperlinks
Hi, friends!
I have a dwf file with many hyperlinks to diferent kind of documents,
xls, doc, pdf, jpg and dwf.
When i open it with Autodesk DWF Viewer 7 I browse all the files without
problem.
I have created a Web.Layout to be used with MGOS.
If I use MGOS with AJAX viewer, I can't "see" any hyperlinks; they are
lost.
If I use MGOS with DWF viewer, it tries to open files at the task pane,
but doesn't found them.
How can I fix this problem.
Thanks in advance.
Lic. Jorge Rubio
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061108/58256b21/attachment.html
More information about the Mapguide-users
