[mapguide-users] Linux and raster support?
Sun Nov 12 13:20:38 EST 2006
Andy Morsell wrote:
> Thanks Frank,
> I was able to get JPG working.  Studio didn't know where it's extents were,
> so I had to create a map with the necessary extents.  I tried to work a bit
> with ECW and MrSID but didn't have much luck, so I'll keep digging at a
> later date on that.  I see that you have many samples in the source, so I'll
> try working with that.  Do you by any chance have any test layers in a
> mapguide repository?  If so, it would be handy if you could export the
> package in MG Admin and then others could import it and look at data and
> layer configurations.
Andy,
I noticed too that Web Studio didn't seem to know about raster extents.  I
don't *think* this is a problem with the driver, just an apsect of how studio
works, though I could be wrong.
By default as built in FDO, GDAL does not include ECW and MrSID support.  If
you need them for the KG project, I can modify that aspect of the build on
the target machine.
BTW, it might be good to scrub off the old mapguide and fdo components
from the KG machine before installing from SVN.  This would avoid duplication
and confusion.
I think this would mostly require the command:
  sudo rm -rf /usr/local/fdo-3.1.0 /usr/local/mapguideopensource
  sudo rm -rf /usr/local/src/mapguide-1.0.1* /usr/local/src/OpenSource_FDO
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the Mapguide-users mailing list
