[mapguide-users] Linux and raster support?
Andy Morsell amorsell at spatialgis.com
Sun Nov 12 13:32:50 EST 2006
Frank,
For the KG project, ECW and MrSID support is not needed at this time, only
JPG.  Those were just a couple of my own test images from one of my existing
MGOS sites that I was playing around with.  I do see support for these
formats being generally important to other users, however, so I'm wondering
if the external components or whatever is needed can be added to subversion
at some point?
Thanks.
Andy
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Sunday, November 12, 2006 10:21 AM
Subject: Re: [mapguide-users] Linux and raster support?
Andy Morsell wrote:
> Thanks Frank,
> I was able to get JPG working.  Studio didn't know where it's extents
> were, so I had to create a map with the necessary extents.  I tried to
> work a bit with ECW and MrSID but didn't have much luck, so I'll keep
> digging at a later date on that.  I see that you have many samples in
> the source, so I'll try working with that.  Do you by any chance have
> any test layers in a mapguide repository?  If so, it would be handy if
> you could export the package in MG Admin and then others could import
> it and look at data and layer configurations.
Andy,
I noticed too that Web Studio didn't seem to know about raster extents.  I
don't *think* this is a problem with the driver, just an apsect of how
studio works, though I could be wrong.
By default as built in FDO, GDAL does not include ECW and MrSID support.  If
you need them for the KG project, I can modify that aspect of the build on
the target machine.
BTW, it might be good to scrub off the old mapguide and fdo components from
the KG machine before installing from SVN.  This would avoid duplication and
confusion.
I think this would mostly require the command:
  sudo rm -rf /usr/local/fdo-3.1.0 /usr/local/mapguideopensource
  sudo rm -rf /usr/local/src/mapguide-1.0.1* /usr/local/src/OpenSource_FDO
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
