[mapguide-users] projection question
Bruce Dechant
bruce.dechant at autodesk.com
Thu Nov 16 17:33:51 EST 2006
Matthew,
The file you want to edit is "nad83" in the "nad" folder. Just add your
entry to the end of the file.
One thing to be aware of is that Studio uses a commercial coordinate
system library; where as, MapGuide open source uses the Proj.4
coordinate system library. These 2 libraries are not fully compatible
with each other.
Thanks,
Bruce
_____
From: Stone, Matthew (DHS-HISP) [mailto:MStone at dhs.ca.gov]
Sent: November 16, 2006 2:09 PM
Subject: [mapguide-users] projection question
I want to be able to use the California Teale Albers NAD83 projection
with the Mapguide OS server version. I see all the data files, and also
see a bunch of files in the "NAD" folder, but don't know which ones to
edit, and for that matter, how to edit the appropriate files so when I
use Studio Enterprise, my projection is recognized. Any ideas? The
following is the code I am using....
# NAD_1983_California_Teale_Albers
<11000> +proj=aea +lat_1=34 +lat_2=40.5 +lat_0=40 +lon_0=-120 +x_0=0
+y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m no_defs <>
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061116/596dc34d/attachment.html
More information about the Mapguide-users
