[mapguide-users] Site corrupt - MG Server fails to start
Jason Birch Jason.Birch at nanaimo.ca
Mon Nov 20 16:18:10 EST 2006
If you're talking about the same paths that I think you are, they are stored in the serverconfig.ini file.
Jason
Sent: Mon 2006-11-20 1:13 PM
Subject: RE: [mapguide-users] Site corrupt - MG Server fails to start
Thanks for the information Bruce, I'll try that next time I see these symptoms (hopefully never again).  Dave Wilson also mentioned in the MapGuide Enterprise discussion group that if the files under Site are deleted, then server will re-create them when started.  I tested this and it worked.  You will end up losing any users and groups you setup (and I'm sure other things, but I don't know exactly what), but I was pleasantly surprised to see that resource service paths were not effected (my repository is not in the default location).
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061120/5fb3b96b/attachment.bin
More information about the Mapguide-users mailing list
