[mapguide-users] Loading Packages
Steve Dang steve.dang at autodesk.com
Tue Nov 21 13:17:40 EST 2006
The package file size limit is 2 GB. It looks like you have no write
access to the LibraryResourceDataFilePath specified in your
serverconfig.ini file.
Steve.
  _____
From: Stone, Matthew (DHS-HISP) [mailto:MStone at dhs.ca.gov]
Sent: Tuesday, November 21, 2006 10:57 AM
Subject: [mapguide-users] Loading Packages
Anyone had luck with this?  I have tried twice after creating huge
packages (almost a gig) of some shape files.  When I try to load them, I
get the following errors in the log...Can anyone assist?  Is there a
limit to the size?
API_NAME:  LoadPackage
STATUS_CODE:     Failed
PACKAGE_NAME:   FromOCH1540C265R831_112006.mgp
PACKAGE_DESC:   Created by ShpLoadProcedure.Execute().
PACKAGE_DATE:   2006-11-20T16:59:57
PACKAGE_SIZE:    789149912
USER_NAME:         mstone
SERVER_NAME:     OCH1540C265R831
SERVER_ADDR:     10.224.66.18
START_TIME:         2006-11-21T09:53:03.033875
END_TIME:  2006-11-21T09:53:05.002625
OPS_FAILED:         572
OPS_RECEIVED:    574
AVRG_OP_TIME:    984.5
ERROR_MESSAGE: A file IO exception occurred:
E:/MapguideOS/Repositories/Library/DataFiles/0ff57d0a-0000-1000-8000-000
bdb55f8ed
STACK_TRACE:      - MgLibraryRepositoryManager.LoadResourcePackage line
176 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\LibraryR
epositoryManager.cpp - MgResourcePackageLoader.Start line 150 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\Resource
PackageLoader.cpp - MgResourcePackageLoader.PerformOperation line 228
file
PackageLoader.cpp - MgResourcePackageLoader.SetResourceData line 520
file
PackageLoader.cpp - MgApplicationRepositoryManager.SetResourceData line
894 file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\Applicat
ionRepositoryManager.cpp - MgFileUtil.CreateDirectory line 313 file
c:\build_tux_area\mgdev_opensource\common\service\util\FileUtil.cpp
OP_DETAILS:
<2006-11-21T09:53:04.83075>
DeleteResource(Library://Data/Data/Assembly_Districts.FeatureSource)
SetResource(Library://Data/Data/Assembly_Districts.FeatureSource,Op1_SET
RESOURCE_CONTENT.xml,Op1_SETRESOURCE_HEADER.xml)
<2006-11-21T09:53:05.002625>
SetResourceData(Library://Data/Data/Assembly_Districts.FeatureSource,Ass
embly_Districts.shp,File,Op2_SETRESOURCEDATA_DATA)
Matthew Stone, MPH
UCSF/CA Dept. of Health Services
Health Information & Strategic Planning (HISP)
Office of County Health Services (OCHS)
1501 Capitol Ave MS 5204
Mailing Address:
PO BOX 997413, MS 5204
Sacramento CA 95899-7413
Physical Address:
1501 Capitol Avenue, Suite 71.5195, MS 5204
Sacramento, CA 95814
_____________________________
PH: 916-552-9918
FAX: 916-552-8260
mstone at dhs.ca.gov
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061121/59a895d8/attachment.html
More information about the Mapguide-users mailing list
