[mapguide-users] problem with OGR provider
Traian Stanev traian.stanev at autodesk.com
Mon Nov 27 11:11:58 EST 2006
Try connecting to the directory where the TAB file is located, rather
than to the file itself.
  _____
Sent: Friday, November 24, 2006 3:42 AM
Subject: RE: [mapguide-users] Weird Error when restarting server on
Linux
I got problem with the OGR provider in Autodesk Map 3D 2007.
The provider is working fine for Oracle and SHP-files, but if I try to
connect MapInfo TAB or MIF/MID-files the following error message
appears.
Autodesk.Gis.Common.Exception: Connect failed
            By Autodesk.Gis.Fdo.Connections.IConnectionImp.Open()
Autodesk.Gis.Map.DataConnect.Plugins.GenericProviderConnectionPlugin.but
tonPendingConnect_Click(Object sender, EventArds e)
Any idea why this error occurs?
Thanks
michaela
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061127/4f12694d/attachment.html
More information about the Mapguide-users mailing list
