[mapguide-users] SetFilter filter function exceptions with sdf
Jack Lee
jack.lee at autodesk.com
Sun Oct 1 23:07:03 EDT 2006
Hi Zak,
The function names are case sensitive. You should change "max(FeatId)" to "Max(FeatId)".
-----Original Message-----
Sent: Sun 10/1/2006 9:29 PM
Cc:
Subject: [mapguide-users] SetFilter filter function exceptions with sdf
Has anyone had any problems using the built in filter functions for
the OSGeo.SDF.3.1 provider via the Mapguide 1.0.1 api?
The capabilities show they are supported but I get the following
exception when trying to use them to filter a Select operation:
An exception occurred in FDO component.
Function not supported
- MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev_opensource\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeaturesSpatial.Execute line 115 file
c:\build_tux_area\mgdev_opensource\server\src\services\feature\OpSelectFeaturesSpatial.cpp
- MgServerSelectFeatures.SelectFeatures line 217 file
c:\build_tux_area\mgdev_opensource\server\src\services\feature\ServerSelectFeatures.cpp
Hopefully I'm just doing something stupid. Here's the php code:
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->AddComputedProperty("MyMax", "max(FeatId)");
$featureClass = $layer->GetFeatureClassName();
$featureReader = $featureService->SelectFeatures($featureSourceId,
$featureClass, $queryOptions);
The featuresourceid points to a session feature source which
references a valid sdf file. I've also tried going the SelectAggregate
route and I've tried other functions listed in the sdf capabilities
xml with similar results.
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061001/3cc72738/attachment.bin
More information about the Mapguide-users
