[mapguide-users] SQL Server 2005
Robert Fortin robert.fortin at autodesk.com
Thu Oct 5 09:46:54 EDT 2006
SQL Server provider is read-write.  There should not be any problem
writing data back.
You would probably have to create a class for the redlined data and use
the standard FDO feature commands against it.
In case this doesn't fit with your db setup for some reason, remember
that there is always the SQL pass through command that you can use and
just pass SQL statement.
It's probably better to get the first approach to work...
RF
  _____
From: Lockyer James [mailto:James.Lockyer at bradford.nhs.uk]
Sent: Thursday, October 05, 2006 3:50 AM
Subject: RE: [mapguide-users] SQL Server 2005
Robert
Thanks....  Think my brain might have gone into overload now... will
bring it back on line in a mo.
Out of interest, as I have managed to create an SQL datastore that can
be seen by Mapguide Enterprise/OS is it possible to save redlined data
to the datastore through the standard FDO-SQL provider, or is the
provider only capable of reading data from the SQL database.
Jim
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061005/6906377c/attachment.html
More information about the Mapguide-users mailing list
