[mapguide-users] FW: Autoselect an object on Map start
Willem Schwarte
willem at giskit.nl
Wed Oct 11 08:50:58 EDT 2006
I have solved this one in the meantime. I've put everything in a
try..catch so I can see exactly where the error occurs, because the
errors are not that clear to me that I can tell at which statement the
error occurred...
But this is working now.
Thanks anyway for replying...
Willem
-----Oorspronkelijk bericht-----
Van: meli-m [mailto:meli-m at arcor.de]
Verzonden: woensdag 11 oktober 2006 13:25
Aan: users at mapguide.osgeo.org
Onderwerp: Re: [mapguide-users] FW: Autoselect an object on Map start
I looked through your code and I think it would be much easier to read
if the
code becomes something clearer. There is no need to wrapp every
statement
int to a try-catch?
Unfortunately I can't test your code, because I don't have support for
php.
The selectionXml you sent to the map is the same in both ways?
Melanie
View this message in context:
http://www.nabble.com/FW%3A-Autoselect-an-object-on-Map-start-tf1697929.
html#a6754547
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
