[mapguide-users] FW: Autoselect an object on Map start
meli-m meli-m at arcor.de
Wed Oct 11 07:24:38 EDT 2006
I looked through your code and I think it would be much easier to read if the
code becomes something clearer. There is no need to wrapp every statement
int to a try-catch?
Unfortunately I can't test your code, because I don't have support for php.
The selectionXml you sent to the map is the same in both ways?
Melanie
View this message in context: http://www.nabble.com/FW%3A-Autoselect-an-object-on-Map-start-tf1697929.html#a6754547
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide-users mailing list
