[mapguide-users] RE: Am i on the Right Track?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Sat Oct 14 14:16:13 EDT 2006
I started something (which did the trick for me)....and then at some
point, someone else modified it a little to make it even more generic. I
think that he was going to see about getting it included with the
install package. This was before the last release, so you may already
have it. It was called passdata.php....
Andrew
Andy Morsell wrote:
> That's right, I had forgotten.  Andrew DeMerchant put a PHP script together
> that would do this:
> https://mapguide.osgeo.org/servlets/ReadMsg?listName=users
> <https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=1877>
> &msgNo=1877
> Andy
>   _____
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Friday, October 13, 2006 11:44 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: Am i on the Right Track?
> Didn't somebody post a code example here that did this in a generic way?
> Darned if I can remember when or who...
> Jason
>   _____
> From: Andy Morsell [@spatialgis.com]
> Sent: Fri 2006-10-13 10:29 PM
> Subject: [mapguide-users] RE: SPAM-LOW: [mapguide-users] RE: Am i on the
> Right Track?
> That code was developed, in part, for a client and I do not have the
> authority to give away the source code.   I can tell you the rough coding
> steps:
> -Grab the selection XML
> -Query the original feature source using the feature ID's from the selection
> XML using the FDO API
> -Retrieve from the query results the key that makes sense to you and your
> data
> -Pass your key values to your external report
> -Your external report then queries the pertinent database tables to produce
> the final report
> Andy
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
