[mapguide-users] RE: RE: RE: PHP version
Jason Birch Jason.Birch at nanaimo.ca
Thu Oct 19 00:11:07 EDT 2006
There are quite a few developer resources that will help you get started with your quest to place a point on the map (and beyond).
First, load the Sheboygan sample and the Php Sample App from the Downloads page.  At least two of the samples in the PHP app include placing pushpins.  These are located at the bottom of this page:
https://mapguide.osgeo.org/downloads.html <https://mapguide.osgeo.org/downloads.html>
under the heading "Samples for MapGuide Open Source 1.0.x".  Ignore the .Net and Java sample apps.
Next, download the Developers Guide (PDF version is best) and the sample code from the Documentation page:
https://mapguide.osgeo.org/documentation.html <https://mapguide.osgeo.org/documentation.html>
Finally, visit this site, for some more advanced developer examples (with links to source code):
http://data.mapguide.com/mapguide/devguide/index.php <http://data.mapguide.com/mapguide/devguide/index.php>
and it looks like Andy still has an unofficial copy of those samples for download available here:
www.spatialgis.com/devguide_june_2006_samples.zip
Jason
Sent: Wed 2006-10-18 6:49 PM
Subject: [mapguide-users] RE: RE: RE: PHP version
Hi Jason,
I have reinstall everything and now everything works perfect. thanks for
your guidance.
By the way, do you know how to adding symbols(pin point) on to the map?
can I know what are the step. I am learning on it using php as the
development tools now .
I am looking forward for your reply and thank you once again.
regards,
Kencana
Jason Birch wrote:
> The first links (the tar files) are source code.  You need to install
> the executable packages which are a bit further down the list.
> If you can't log into the administrator, then there's definitely
> something wrong with your installation.  Let us know when you get the
> old version uninstalled and 1.0.2 installed.  In your case, you will
> likely want to choose IIS integration.
> Jason
> -----Original Message-----
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Wednesday, October 18, 2006 02:12
> Subject: [mapguide-users] RE: RE: PHP version
> Hi Jason,
> I guess I have install the old version of mapguide. first of all sorry
> if I am troubling you. can I know the step of installing the opensource
> 1.0.2?I download tar file for that. but I am confused in how to install
> it.
> currently I am using windows server 2003. I am not able to log in into
> map administrator, where it didnt show anything only blank page.and I am
> trying to view the shebboygan map but it shows nothing. I am looking
> forward for your reply.
> Regards,
> Kencana
> Jason Birch wrote:
>> It's difficult to troubleshoot your problems with the level of details
>> you're providing.
>> What version of MapGuide are you trying to install?  I would suggest
>> starting with MapGuide Open Source 1.0.2, as it has a much cleaner
>> installation than any of the earlier versions.  Either that or waiting
>> for the SP1 from Autodesk.  There are known issues with some locales
>> in earlier versions of MapGuide.
>> What operating system are you running?
>> Are you able to login to the Map Administrator?
>> Are you able to login to mapguide/mapagent/index.html and get a value
>> for the EnumerateResources query?
>> Where are you unable to see the map?  In Studio?  In the sample
>> application?
>> What data are you looking at?  Sheboygan?  Your own data?
>> Is there any other information you can provide that could help with
>> the resolution of this problem?
>> Jason
>> Sent: Tue 2006-10-17 11:40 PM
>> Subject: [mapguide-users] RE: PHP version
>> Hi Jason,
>> Thanks for the reply. I have try to install mapguide 2007 with IIS>PHP
>> config.
>> But when i try to view the map it shows nothing. I have follow the
>> installation instruction bt still nothing.
>> I hope you can give me solution. I am looking forward for your reply
>> and thank you.
>> Regards,
>> Kencana
>> Jason Birch wrote:
>>> MapGuide Open Source (and I believe Enterprise) are reliant on PHP
>>> version 5.0.5.
>>> At least, that was the case last time I checked (several users have
>>> found this out by running with newer unsupported versions of PHP) and
>>> PHP 5.0.5 is the version which is bundled with MapGuide.
>>> Jason
>>> Sent: Tue 2006-10-17 9:35 PM
>>> Subject: [mapguide-users] PHP version
>>> Hi guys,
>>> I am new to this "Autodesk Mapguide 2007" and I want to ask about the
>>> php version which compatible to this software. I am looking forward
>>> for the reply and thank you very much.
>>> Regards,
>>> Kencana
>>> View this message in context:
>>> http://www.nabble.com/PHP-version-tf2464139.html#a6869321
>>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> http://www.nabble.com/PHP-version-tf2464139.html#a6870320
> http://www.nabble.com/PHP-version-tf2464139.html#a6872289
View this message in context: http://www.nabble.com/PHP-version-tf2464139.html#a6889237
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061018/80c23e10/attachment.bin
More information about the Mapguide-users mailing list
