PHP version
Kencana
bluesky_dyx at hotmail.com
Wed Oct 18 21:49:32 EDT 2006
Hi Jason,
I have reinstall everything and now everything works perfect. thanks for
your guidance.
By the way, do you know how to adding symbols(pin point) on to the map?
can I know what are the step. I am learning on it using php as the
development tools now .
I am looking forward for your reply and thank you once again.
regards,
Kencana
Jason Birch wrote:
> The first links (the tar files) are source code. You need to install
> the executable packages which are a bit further down the list.
> If you can't log into the administrator, then there's definitely
> something wrong with your installation. Let us know when you get the
> old version uninstalled and 1.0.2 installed. In your case, you will
> likely want to choose IIS integration.
> Jason
> -----Original Message-----
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Wednesday, October 18, 2006 02:12
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: RE: PHP version
> Hi Jason,
> I guess I have install the old version of mapguide. first of all sorry
> if I am troubling you. can I know the step of installing the opensource
> 1.0.2?I download tar file for that. but I am confused in how to install
> it.
> currently I am using windows server 2003. I am not able to log in into
> map administrator, where it didnt show anything only blank page.and I am
> trying to view the shebboygan map but it shows nothing. I am looking
> forward for your reply.
> Regards,
> Kencana
> Jason Birch wrote:
>> It's difficult to troubleshoot your problems with the level of details
>> you're providing.
>> What version of MapGuide are you trying to install? I would suggest
>> starting with MapGuide Open Source 1.0.2, as it has a much cleaner
>> installation than any of the earlier versions. Either that or waiting
>> for the SP1 from Autodesk. There are known issues with some locales
>> in earlier versions of MapGuide.
>> What operating system are you running?
>> Are you able to login to the Map Administrator?
>> Are you able to login to mapguide/mapagent/index.html and get a value
>> for the EnumerateResources query?
>> Where are you unable to see the map? In Studio? In the sample
>> application?
>> What data are you looking at? Sheboygan? Your own data?
>> Is there any other information you can provide that could help with
>> the resolution of this problem?
>> Jason
>> ________________________________
>> Sent: Tue 2006-10-17 11:40 PM
>> Subject: [mapguide-users] RE: PHP version
>> Hi Jason,
>> Thanks for the reply. I have try to install mapguide 2007 with IIS>PHP
>> config.
>> But when i try to view the map it shows nothing. I have follow the
>> installation instruction bt still nothing.
>> I hope you can give me solution. I am looking forward for your reply
>> and thank you.
>> Regards,
>> Kencana
>> Jason Birch wrote:
>>> MapGuide Open Source (and I believe Enterprise) are reliant on PHP
>>> version 5.0.5.
>>> At least, that was the case last time I checked (several users have
>>> found this out by running with newer unsupported versions of PHP) and
>>> PHP 5.0.5 is the version which is bundled with MapGuide.
>>> Jason
>>> Sent: Tue 2006-10-17 9:35 PM
>>> Subject: [mapguide-users] PHP version
>>> Hi guys,
>>> I am new to this "Autodesk Mapguide 2007" and I want to ask about the
>>> php version which compatible to this software. I am looking forward
>>> for the reply and thank you very much.
>>> Regards,
>>> Kencana
>>> View this message in context:
>>> http://www.nabble.com/PHP-version-tf2464139.html#a6869321
>>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> http://www.nabble.com/PHP-version-tf2464139.html#a6870320
> http://www.nabble.com/PHP-version-tf2464139.html#a6872289
View this message in context: http://www.nabble.com/PHP-version-tf2464139.html#a6889237
More information about the Mapguide-users
