[mapguide-users] MG 1.0.2
Andy Morsell
amorsell at spatialgis.com
Wed Oct 25 20:34:32 EDT 2006
I realize that I mis-wrote. That is the Apache http.conf file, not Tomcat.
Andy
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, October 25, 2006 5:26 PM
Subject: RE: [mapguide-users] MG 1.0.2
Haris,
It looks like your JSP is not compiling and executing correctly since you
are seeing the HTML output of that file. Is Tomcat configured and running?
Did you do the bundled Apache/Tomcat install or did you configure Tomcat
manually? Make sure this section is in Tomcat's http.conf file (paths may
be different for you):
#-----------------Start Tomcat connector support
LoadModule jk_module modules/mod_jk.so
JkWorkersFile "C:/Program Files/Apache
Group/Apache2/conf/workers.properties"
# Where to put jk logs
JkLogFile "C:/Program Files/Apache Group/Apache2/logs/mod_jk.log"
# Set the jk log level [debug/error/info]
JkLogLevel info
# Select the log format
JkLogStampFormat "[%a %b %d %H:%M:%S %Y] "
# JkOptions indicate to send SSL KEY SIZE,
JkOptions +ForwardKeySize +ForwardURICompat -ForwardDirectories
# JkRequestLogFormat set the request format
JkRequestLogFormat "%w %V %T"
# Send everything for context /examples to worker named
# worker1 (ajp13)
JkMount /mapguide/mapviewerjava/* worker1
Redirect /mapguide/mapviewerajax/
http://127.0.0.1/mapguide/mapviewerjava/ajaxviewer.jsp
Redirect /mapguide/mapviewerdwf/
http://127.0.0.1/mapguide/mapviewerjava/dwfviewer.jsp
#-----------------End Tomcat connector support
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
Sent: Wednesday, October 25, 2006 5:01 PM
Subject: [mapguide-users] MG 1.0.2
After installing mg 1.0.2 from instalation files I downloaded from osgeo, I
am getting this in layer preview or map or web layout in MG studio 2007.
Other things are working except I can't see anything :)
-Copyright (C) 2004-2006 Autodesk, Inc.
-This library is free software; you can redistribute it and/or
-modify it under the terms of version 2.1 of the GNU Lesser
-General Public License as published by the Free Software Foundation.
-This library is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-Lesser General Public License for more details.
-You should have received a copy of the GNU Lesser General Public
-License along with this library; if not, write to the Free Software
-Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301
USA
<%@ page contentType="text/html; charset=UTF-8" pageEncoding="UTF-8" %>
<%@ page import="org.osgeo.mapguide.*" %>
<%@ page import="java.util.*" %>
<%@ page import="java.io.*" %>
<%@ page import="javax.servlet.jsp.*" %>
<%@ page import="javax.servlet.http.*" %>
<%@ include file="mainframe.jsp" %>
response.setContentType("text/html; charset=UTF-8");
request.setCharacterEncoding("UTF-8");
MgLocalizer.SetLocalizedFilesPath(getServletContext().getRealPath("/") +
"localized/");
GenerateMainPage(0, request, response);
Any ideas?
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061025/160aae9a/attachment.html
More information about the Mapguide-users
