[mapguide-users] Turning on layer from task frame
Andy Morsell
amorsell at spatialgis.com
Fri Oct 27 16:20:55 EDT 2006
You can use the MGLayer SetVisible method. Note that you will also have to
do a client-side API refresh in order to get your map and legend to update
accordingly.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
From: Jim O'Leary [mailto:joleary.public at gmail.com]
Sent: Friday, October 27, 2006 12:51 PM
Subject: [mapguide-users] Turning on layer from task frame
Is there a way to turn on a layer (that is, programmatically check the layer
in the Layers pane) from the Task frame?
I have a select box of layers in my task frame. When the user selects a
layer, I would like the same layer to be checked in the Layer pane. Right
now the user has to check the layer manually, or else the layer is not
selectable.
Thanks
View this message in context:
http://www.nabble.com/Turning-on-layer-from-task-frame-tf2522746.html#a70372
12
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
