[mapguide-users] perfomance test
Haris Kurtagic
haris at sl-king.com
Sun Oct 29 17:51:20 EST 2006
Yes run 16 and divide 16. ( I am checking with more )
and yes, I go trough feature reader and read every data value for every
row.
Haris
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Sunday, October 29, 2006 11:48 PM
To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
Subject: RE: [mapguide-users] perfomance test
If you are looping 16 times and then dividing the total time by 16, then
it's probably fine. Your timing includes both executing the select
command and then reading through the resulting feature reader?
Traian
-----Original Message-----
Sent: Sun 10/29/2006 5:40 PM
Cc:
Thank you for all your suggestions. This is my first test so :)
Yes, I also think that other factors have more influence.
I' ve used clock() on windows and I ran it in loop of 16.
I suppose I should take some much larger data set.
Thanks,
Haris
Sent: Sunday, October 29, 2006 11:32 PM
OK. All I was saying is that EnvelopeIntersects does not incur a
secondary geometry filter processing for each feature in the SDF
provider, which Intersects does. I would have expected a significant
difference between Intersects and EnvelopeIntersects for the SDF
provider. Also, EnvelopeIntersects is what MapGuide uses to render every
map.
About the FGF thing -- yes SDF has the luxury of not having to
convert geometry formats, so in the limit, it would be faster than a
provider that converts, but (in my opinion) there are many other factors
which have a much bigger impact on performance, than a simple geometry
conversion loop.
Also, another question... How do you do the timing? If you use
the Windows clock, it has a resolution of 16 milliseconds, which makes
the accuracy of the 0.031 sec measurement for SDF very doubtful to me,
unless you repeated the operation 100 times and then took the total time
and divided by 100, for example.
Traian
Sent: Sun 10/29/2006 5:18 PM
Cc:
Yes, I've tried envelope but I wanted to try more
complicated query (to use primary and secondary filter in Oracle) and
also couldn't see huge difference on this small set.
If I understood you correctly you mean sdf provider is
not loosing time in converting to FGF format ?
I agree on that but that is format use in MG, so that is
one + for sdf :)
Haris
Sent: Sunday, October 29, 2006 11:13 PM
Did you try an EnvelopeIntersects filter? That one is by
far the most common one, rather than Intersects.
It is not surprising that SDF is fastest by far... The
SDF provider does not add any intelligence to the data and stores
everything in FGF format so you are basically getting back a pointer
into database memory when you ask for the geometry.
Traian
Sent: Sun 10/29/2006 4:57 PM
Cc:
Subject: [mapguide-users] perfomance test
After some discussion's here on this list I got
interested in comparing different data source and fdo providers.
So, I have used an test application written as
pure FDO client.
I have run test again sdf, shp , 10gr2 and xe,
using osgeo sdf, shp and king.oracle provider.
Data used in test is Sheboygan_Parcels.sdf from
MG unittest data.
Before I wrote the results I would like to make
strong point that this could be altogether false results, I don't know
anything about writing true fair tests.
As my lawyer told me I should put in here :
whatever is written is not promise, could be wrong and ..... :)
17565 features read in case 1,2, 6681 fetaures
in 3,4
results are in seconds
Test case 1: No geometry filter, Fetch all
attributes
SDF 0.937
SHP 8.531
10GR2 18.172
XE 18.500
Test case 2: No geometry filter, Fetch Geometry
and Identity
SDF 0.031
SHP 0.109
10GR2 1.938
XE 1.735
Test Case 3: Geometry Filter, Fetch all
attributes
SDF 0.390
SHP 3.391
10GR2 6.906
XE 6.218
Test Case 4: Geometry Filter, Fetch Geometry
and Identity
SDF 0.031
SHP 0.140
10GR2 0.891
XE 0.797
Geometry Filter was: SHPGEOM INTERSECTS
GeomFromText('POLYGON ((-87.72 44, -86 44, -86 42, -87.72 42, -87.72
44))')
and for SDF and King.Oracle it returns same
number of features 6683 which is good
shape provider returned : 6681 ?
Original SDF file was copied to Oracle using
that same tool, I call it Fdo2Sdo.
Oracle 10GR2 is running on my same desktop in
virtual machine and XE on localhost.
My Remarks:
SDF is really fast and highly optimized for this
kind of queries. Test Case 4 would be the most used case in real word
app. and differences there are smallest.
I think if you add overhead of MG and other
overheads than influence would be even smaller.
I think these tests are very unfavorable to
Oracle.
This test is run with very small data set (just
17565 polygons), I believe much larger data sets would be more
preferable to Oracle.
I also couldn't run test with ordering or
grouping (sdf,shp don't support it). I run this test immediately after
installing Oracle, not using any spatial index optimization
and also provider is not highly optimized as
could be.
Here I am comparing file system to database ( it
is little unusual ), It would make more sense to test against other db.
I will make this tool freely available very
soon, so you will be able to run test by your self's, and also it would
be nice to test other data sources and providers.
I hope that someone will find this tests useful.
I will welcome every comment on this and if I
made this tests wrongly please do tell me.
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061029/93b37b8c/attachment.html
More information about the Mapguide-users
