[mapguide-users] Microsoft JScript runtime error
Adam Herbert adam at aemsaustralia.com.au
Tue Sep 5 19:36:26 EDT 2006
Thanks, works a treat!
From: Thomas M. Tuerke [mailto:thomas.m.tuerke at autodesk.com]
Sent: Wednesday, 6 September 2006 7:06 AM
Subject: RE: [mapguide-users] Microsoft JScript runtime error
There may be a timing issue involved.  Seems like there are two windows
at play here, and the grandparent in question may not be ready (it may
still be loading) even though your page is already done (your onPageLoad
has fired.)
JavaScript is pretty compartmentalized, so there may be security
constraints that prevent you from realizing whether another window has
loaded (that's been true for IE, anyway.)
One workaround might be to fire off a setTimeout on page load, where the
timeout would call the Zoom, which predicated on the assumption that all
pages finish loading by the time the timeout expires.  Another option is
to have the grandparent do the actual ZoomToView upon its reaching
loaded state.
- Thomas
From: Adam Herbert [mailto:adam at aemsaustralia.com.au]
Sent: Tuesday, September 05, 2006 1:57 PM
Subject: [mapguide-users] Microsoft JScript runtime error
I am running this code:
<script type="text/javascript">
            function onPageLoad()
                parent.parent.ZoomToView(<%=x %>, <%=y %>, 110000,
true);
            </script>
</head>
<body class="AppFrame" onload="onPageLoad()">
And getting this error:
Microsoft JScript runtime error: Object doesn't support this property or
method
mapFrame.ZoomToView(x,y,scale,refresh); on Line 213 of ajaxviewer.aspx
I can run this fine from a link on the same page and point it to the
scriptFrame but when I try to run the onPageLoad function it fails.
Any ideas on what I might be doing wrong?
Adam Herbert
IT Manager
AEM Solutions Pty Ltd
PO Box 514, Toowoomba Q. 4350
Phone: 07 4613 0455
Cell: 0437 599 907
Website: www.aemsaustralia.com.au <http://www.aemsaustralia.com.au>
Important Disclaimer and Warning
AEMS does not represent or warrant that any attached files are free from
computer viruses or other defects. The attached files are provided, and
may only be used, on the basis that the user assumes all responsibility
for any loss, damage or consequences resulting directly or indirectly
from use of the attached files. The liability of AEMS in any event is
limited to either the re-supply of the attached files or the cost of
having the attached files re-supplied.
NOTE: The views expressed by the individual in this message do not
necessarily reflect those of the organisation.
AEMS is committed to protecting the privacy of individuals, and is bound
by the principles of the Commonwealth Privacy Act (1988).
The information contained in this message is confidential and may be
legally privileged. The message is intended solely for the addressee(s).
If you are not the intended recipient, you are hereby notified that any
use, dissemination, or reproduction is strictly prohibited and may be
unlawful. If you are not the intended recipient, please contact the
sender by return e-mail and destroy all copies of the original message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060906/0b13311b/attachment.html
More information about the Mapguide-users mailing list
