WMS GetFeatureInfo request problem
Yewondwossen Assefa assefa at dmsolutions.ca
Tue Sep 5 17:47:45 EDT 2006
Hi There,
  I was trying to use a wms client (udig) to test wms functionalities of
a maguide wms server.  GetCapbilities and GetMap seem to work as
expected if the correct parameters are provided.  The issue I am having
is with GetFeatureInfo. The request never returns any element. It looks
something like this :
http://127.0.0.1:8008/mapguide/mapagent/mapagent.fcgi?Y=1&X=1&SERVICE=WMS&INFO_FORMAT=text/html&LAYERS=Samples/Sheboygan/Layers/Parcels&FORMAT=image/png&HEIGHT=3&REQUEST=GetFeatureInfo&WIDTH=3&BBOX=-87.71831536625463,43.74885252872668,-87.71826930205252,43.748898592928775&SRS=EPSG:4326&QUERY_LAYERS=Samples%2FSheboygan%2FLayers%2FParcels&VERSION=1.1.1
Note the size of the image is 3/3 and x=1,y=1 (generated by udig).
Doing a GetMap using the same parameters of bbox and layer returns an
image. The layer is Queryable according to the capabilities document.
Does any body have a hint of what is wrong ? Do people have successfully
deployed wms servers where the GetFeatureInfo was working as expected ?
Thanks
PS few additional info
- I am under the impression that the low level code uses a point element
with an intersect operation to do the search. In previous tests I had
issues with a point element and an intersect operation and had to use a
small rectangle as a work around when using the mapagent
QUERYMAPFEATURES operation. Not sure if it this helps.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the Mapguide-users mailing list
