[mapguide-users] Re: maplab or mgstudio??
Paul Spencer
pspencer at dmsolutions.ca
Fri Sep 8 08:22:26 EDT 2006
Web Studio is an open source contribution. It provides sufficient
functionality to take raw data and get to the point of being able to
produce a map. Due to time and budget constraints, that was seen as
the minimum necessary to make the open source version of MapGuide
useable. If you've created a map definition, you can then use it
with the php viewer sample. Alternately, you can develop code
against the Web Tier API to display the map.
Web Studio is designed to be flexible and it would be relatively
straight forward to add additional functionality to it. We will
gladly accept contributions from the community in the form of code or
financial backing to implement additional features.
Cheers
Paul
On 8-Sep-06, at 3:59 AM, Ivan Miličević wrote:
> You can use mgstudio, he is not expired at 1.9.2006
> -----Original Message-----
> From: anakando [mailto:anakando at yahoo.com]
> Sent: 8. rujan 2006 5:45
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] Re: maplab or mgstudio??
> Hi all..
> thanks for your explaination..i appreciate that..
> i have searching for a web studio documentation and i found that
> one of web
> studio limitations is web studio cannot creates a web layout. is
> that mean i
> still have to use mg studio to create a web layout?if that so,i
> should used
> mgstudio from earlier and never care about web studio because both
> of these
> products doing same operations.further more, mgstudio offer more
> functions
> rather than web studio..am i right?? if that so, what is the
> purpose of webs
> tudio actually?please correct me i am wrong.
> Zak James wrote:
>> Hi,
>> Maplab is very tightly tied to UMN Mapserver and won't do anything
>> useful for a mapguide application.
>> Kenneth is correct when he states that Web Studio performs
>> essentially
>> the same function as the commercial Studio application. It has
>> several
>> significant limitations but for simple applications you should be
>> able
>> to get everything done with Web Studio. It does allow you to create,
>> edit and manage resources in the repository.
>> You can also use the mapagent (http://localhost:8008/mapguide/
>> mapagent
>> in a default install) to make repository modifications that Web
>> Studio
>> doesn't support yet.
>> N.B. I made a significant bugfix to the file upload code after the
>> Mapguide Open Source 1.0.1 release so you should get the svn version
>> if you need that functionality. If you can wait, It will be rolled
>> into the next 1.0.x release.
>> zak
>> On 9/7/06, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
>>> You can also upload Features through WebStudio.
>>> I haven't tried maplab.
>>> anakando skrev:
>>> thanks for your reply..
>>> base on my knowledge, the purpose of webstudio is to manage the data
>>> resource that already located in server.am i right? i just need
>>> 'something'
>>> that can do like mgstudio..i'm postgraduate student..it's hard
>>> for me to
>>> buy
>>> a mgstudio license only for education purpose!so here i need to
>>> know any
>>> ssoftware or program that can used to create,edit and manage data
>>> resource
>>> beside mgstudio..i was informed by my friend that i can use
>>> maplab or
>>> ka-map
>>> rather than mgstudio..did someone have tried this before?how can
>>> maplab
>>> be
>>> integrated with mapguide even both of maplab and mgos is open source
>>> program?
>>> Kenneth, GEOGRAF A/S wrote:
>>> Yes, you may use WebStudio. It is included in the most recent
>>> MapGuide
>>> OpenSource release, but may also be downloaded from osgeo.
>>> ana kando skrev:
>>> is there another way for me to manage the data instead of using
>>> mgstudio??maybe i would prefer using free downloadable maplab, ka-
>>> map,
>>> chameleon etc rather than buying mgstudio...
>>> Stay in the know. Pulse on the new Yahoo.com. Check it out.
>>> <http://us.rd.yahoo.com/evt=42974/*http://www.yahoo.com/preview>
>> Zak James
>> Applications and Software Development
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/maplab-or-mgstudio---tf2224604.html#a6202474
> Sent from the OSGeo MapGuide forum at Nabble.com.
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mapguide-users
