[mapguide-users] Re: maplab or mgstudio??
anakando
anakando at yahoo.com
Mon Sep 11 00:38:24 EDT 2006
thanks for replies..
i want to simplify my question. Actually i need to know either i still
enable to create a web layout without mgstudio or not..i want to start my
web base project from gathering data until i publish the map into website
without mgstudio..just using web studio..it is possible? it's that all i
want to know..thank you
Paul Spencer-2 wrote:
> Hi,
> Web Studio is an open source contribution. It provides sufficient
> functionality to take raw data and get to the point of being able to
> produce a map. Due to time and budget constraints, that was seen as
> the minimum necessary to make the open source version of MapGuide
> useable. If you've created a map definition, you can then use it
> with the php viewer sample. Alternately, you can develop code
> against the Web Tier API to display the map.
> Web Studio is designed to be flexible and it would be relatively
> straight forward to add additional functionality to it. We will
> gladly accept contributions from the community in the form of code or
> financial backing to implement additional features.
> Cheers
> Paul
> On 8-Sep-06, at 3:59 AM, Ivan Miličević wrote:
>> You can use mgstudio, he is not expired at 1.9.2006
>> -----Original Message-----
>> From: anakando [mailto:anakando at yahoo.com]
>> Sent: 8. rujan 2006 5:45
>> To: users at mapguide.osgeo.org
>> Subject: Re: [mapguide-users] Re: maplab or mgstudio??
>> Hi all..
>> thanks for your explaination..i appreciate that..
>> i have searching for a web studio documentation and i found that
>> one of web
>> studio limitations is web studio cannot creates a web layout. is
>> that mean i
>> still have to use mg studio to create a web layout?if that so,i
>> should used
>> mgstudio from earlier and never care about web studio because both
>> of these
>> products doing same operations.further more, mgstudio offer more
>> functions
>> rather than web studio..am i right?? if that so, what is the
>> purpose of webs
>> tudio actually?please correct me i am wrong.
>> Zak James wrote:
>>> Hi,
>>> Maplab is very tightly tied to UMN Mapserver and won't do anything
>>> useful for a mapguide application.
>>> Kenneth is correct when he states that Web Studio performs
>>> essentially
>>> the same function as the commercial Studio application. It has
>>> several
>>> significant limitations but for simple applications you should be
>>> able
>>> to get everything done with Web Studio. It does allow you to create,
>>> edit and manage resources in the repository.
>>> You can also use the mapagent (http://localhost:8008/mapguide/
>>> mapagent
>>> in a default install) to make repository modifications that Web
>>> Studio
>>> doesn't support yet.
>>> N.B. I made a significant bugfix to the file upload code after the
>>> Mapguide Open Source 1.0.1 release so you should get the svn version
>>> if you need that functionality. If you can wait, It will be rolled
>>> into the next 1.0.x release.
>>> zak
>>> On 9/7/06, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
>>>> You can also upload Features through WebStudio.
>>>> I haven't tried maplab.
>>>> anakando skrev:
>>>> thanks for your reply..
>>>> base on my knowledge, the purpose of webstudio is to manage the data
>>>> resource that already located in server.am i right? i just need
>>>> 'something'
>>>> that can do like mgstudio..i'm postgraduate student..it's hard
>>>> for me to
>>>> buy
>>>> a mgstudio license only for education purpose!so here i need to
>>>> know any
>>>> ssoftware or program that can used to create,edit and manage data
>>>> resource
>>>> beside mgstudio..i was informed by my friend that i can use
>>>> maplab or
>>>> ka-map
>>>> rather than mgstudio..did someone have tried this before?how can
>>>> maplab
>>>> be
>>>> integrated with mapguide even both of maplab and mgos is open source
>>>> program?
>>>> Kenneth, GEOGRAF A/S wrote:
>>>> Yes, you may use WebStudio. It is included in the most recent
>>>> MapGuide
>>>> OpenSource release, but may also be downloaded from osgeo.
>>>> ana kando skrev:
>>>> is there another way for me to manage the data instead of using
>>>> mgstudio??maybe i would prefer using free downloadable maplab, ka-
>>>> map,
>>>> chameleon etc rather than buying mgstudio...
>>>> Stay in the know. Pulse on the new Yahoo.com. Check it out.
>>>> <http://us.rd.yahoo.com/evt=42974/*http://www.yahoo.com/preview>
>>> Zak James
>>> Applications and Software Development
>>> DM Solutions Group Inc.
>>> http://www.dmsolutions.ca
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> View this message in context:
>> http://www.nabble.com/maplab-or-mgstudio---tf2224604.html#a6202474
>> Sent from the OSGeo MapGuide forum at Nabble.com.
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
View this message in context: http://www.nabble.com/maplab-or-mgstudio---tf2224604.html#a6240989
More information about the Mapguide-users
