[mapguide-users] Re: maplab or mgstudio??
Zak James
zak4ms at gmail.com
Mon Sep 11 11:06:40 EDT 2006
You can't create or edit a weblayout with Web Studio, however if you
don't have the commercial studio application (or the preview version
available from Autodesk) you can use the mapagent application included
with the web extensions to manipulate an existing one.
1. load http://localhost:8008/mapguide/mapagent and perform a
getresourcecontent operation on the weblayout included with the
Sheboygan sample data set.
2. Save the XML source using your web browser.
3. Edit the XML in a text editor so that the MapDefinition reference
points to your own map.
4. Use Mapagent's setresourcecontent to put the modified file in the repository.
zak
On 9/11/06, anakando <anakando at yahoo.com> wrote:
> thanks for replies..
> i want to simplify my question. Actually i need to know either i still
> enable to create a web layout without mgstudio or not..i want to start my
> web base project from gathering data until i publish the map into website
> without mgstudio..just using web studio..it is possible? it's that all i
> want to know..thank you
> Paul Spencer-2 wrote:
> > Hi,
> > Web Studio is an open source contribution. It provides sufficient
> > functionality to take raw data and get to the point of being able to
> > produce a map. Due to time and budget constraints, that was seen as
> > the minimum necessary to make the open source version of MapGuide
> > useable. If you've created a map definition, you can then use it
> > with the php viewer sample. Alternately, you can develop code
> > against the Web Tier API to display the map.
> > Web Studio is designed to be flexible and it would be relatively
> > straight forward to add additional functionality to it. We will
> > gladly accept contributions from the community in the form of code or
> > financial backing to implement additional features.
> > Cheers
> > Paul
> > On 8-Sep-06, at 3:59 AM, Ivan Miličević wrote:
> >> You can use mgstudio, he is not expired at 1.9.2006
> >> -----Original Message-----
> >> From: anakando [mailto:anakando at yahoo.com]
> >> Sent: 8. rujan 2006 5:45
> >> To: users at mapguide.osgeo.org
> >> Subject: Re: [mapguide-users] Re: maplab or mgstudio??
> >> Hi all..
> >> thanks for your explaination..i appreciate that..
> >> i have searching for a web studio documentation and i found that
> >> one of web
> >> studio limitations is web studio cannot creates a web layout. is
> >> that mean i
> >> still have to use mg studio to create a web layout?if that so,i
> >> should used
> >> mgstudio from earlier and never care about web studio because both
> >> of these
> >> products doing same operations.further more, mgstudio offer more
> >> functions
> >> rather than web studio..am i right?? if that so, what is the
> >> purpose of webs
> >> tudio actually?please correct me i am wrong.
> >> Zak James wrote:
> >>> Hi,
> >>> Maplab is very tightly tied to UMN Mapserver and won't do anything
> >>> useful for a mapguide application.
> >>> Kenneth is correct when he states that Web Studio performs
> >>> essentially
> >>> the same function as the commercial Studio application. It has
> >>> several
> >>> significant limitations but for simple applications you should be
> >>> able
> >>> to get everything done with Web Studio. It does allow you to create,
> >>> edit and manage resources in the repository.
> >>> You can also use the mapagent (http://localhost:8008/mapguide/
> >>> mapagent
> >>> in a default install) to make repository modifications that Web
> >>> Studio
> >>> doesn't support yet.
> >>> N.B. I made a significant bugfix to the file upload code after the
> >>> Mapguide Open Source 1.0.1 release so you should get the svn version
> >>> if you need that functionality. If you can wait, It will be rolled
> >>> into the next 1.0.x release.
> >>> zak
> >>> On 9/7/06, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> >>>> You can also upload Features through WebStudio.
> >>>> I haven't tried maplab.
> >>>> anakando skrev:
> >>>> thanks for your reply..
> >>>> base on my knowledge, the purpose of webstudio is to manage the data
> >>>> resource that already located in server.am i right? i just need
> >>>> 'something'
> >>>> that can do like mgstudio..i'm postgraduate student..it's hard
> >>>> for me to
> >>>> buy
> >>>> a mgstudio license only for education purpose!so here i need to
> >>>> know any
> >>>> ssoftware or program that can used to create,edit and manage data
> >>>> resource
> >>>> beside mgstudio..i was informed by my friend that i can use
> >>>> maplab or
> >>>> ka-map
> >>>> rather than mgstudio..did someone have tried this before?how can
> >>>> maplab
> >>>> be
> >>>> integrated with mapguide even both of maplab and mgos is open source
> >>>> program?
> >>>> Kenneth, GEOGRAF A/S wrote:
> >>>> Yes, you may use WebStudio. It is included in the most recent
> >>>> MapGuide
> >>>> OpenSource release, but may also be downloaded from osgeo.
> >>>> ana kando skrev:
> >>>> is there another way for me to manage the data instead of using
> >>>> mgstudio??maybe i would prefer using free downloadable maplab, ka-
> >>>> map,
> >>>> chameleon etc rather than buying mgstudio...
> >>>> Stay in the know. Pulse on the new Yahoo.com. Check it out.
> >>>> <http://us.rd.yahoo.com/evt=42974/*http://www.yahoo.com/preview>
> >>> Zak James
> >>> Applications and Software Development
> >>> DM Solutions Group Inc.
> >>> http://www.dmsolutions.ca
> >>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> >>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> >> View this message in context:
> >> http://www.nabble.com/maplab-or-mgstudio---tf2224604.html#a6202474
> >> Sent from the OSGeo MapGuide forum at Nabble.com.
> > |Paul Spencer pspencer at dmsolutions.ca |
> > |Applications & Software Development |
> > |DM Solutions Group Inc http://www.dmsolutions.ca/|
> View this message in context: http://www.nabble.com/maplab-or-mgstudio---tf2224604.html#a6240989
Zak James
More information about the Mapguide-users
