[mapguide-users] Problems with MySQL
Bruce Dechant bruce.dechant at autodesk.com
Tue Sep 12 15:52:34 EDT 2006
Adam,
Can you supply any addition information like:
-          Version of MySQL you are using
-          Geometry type you are having problems with
-          Version of FDO you are using
I have been successful in creating maps from MySQL data using (polygons,
lines and points).
Bruce
  _____
From: Adam Herbert [mailto:adam at aemsaustralia.com.au]
Sent: September 11, 2006 5:43 PM
Subject: RE: [mapguide-users] Problems with MySQL
So I guess that's a no then?
  _____
Sent: Thursday, 7 September 2006 9:49 AM
Subject: [mapguide-users] Problems with MySQL
Has anybody got FDO's using MySQL data sources working properly? I can
get it to read the data but it is not selectable and it doesn't seem to
recognise the geometry types properly.
Thanks.
Adam Herbert
IT Manager
AEM Solutions Pty Ltd
PO Box 514, Toowoomba Q. 4350
Phone: 07 4613 0455
Cell: 0437 599 907
Website: www.aemsaustralia.com.au <http://www.aemsaustralia.com.au>
Important Disclaimer and Warning
AEMS does not represent or warrant that any attached files are free from
computer viruses or other defects. The attached files are provided, and
may only be used, on the basis that the user assumes all responsibility
for any loss, damage or consequences resulting directly or indirectly
from use of the attached files. The liability of AEMS in any event is
limited to either the re-supply of the attached files or the cost of
having the attached files re-supplied.
NOTE: The views expressed by the individual in this message do not
necessarily reflect those of the organisation.
AEMS is committed to protecting the privacy of individuals, and is bound
by the principles of the Commonwealth Privacy Act (1988).
The information contained in this message is confidential and may be
legally privileged. The message is intended solely for the addressee(s).
If you are not the intended recipient, you are hereby notified that any
use, dissemination, or reproduction is strictly prohibited and may be
unlawful. If you are not the intended recipient, please contact the
sender by return e-mail and destroy all copies of the original message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060912/00872374/attachment.html
More information about the Mapguide-users mailing list
