[mapguide-users] POOL:DWF or AJAX
Ivan Miličević
ivan at ineo.hr
Fri Sep 15 11:15:01 EDT 2006
I've got it, thnx Jason.
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 15. rujan 2006 17:09
Subject: RE: [mapguide-users] POOL:DWF or AJAX
Ivan, you've probably figured this out from the path that Kenneth provided,
but this is the command to check out MapGuide
svn checkout https://mapguide.osgeo.org/svn/mapguide/trunk/MgDev
"D:\OSGeo\MGDev" --username YourOSGeoID --password YourOSGeoPwd
Jason
_____
From: Kenneth, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: Friday, September 15, 2006 07:26
Subject: Re: [mapguide-users] POOL:DWF or AJAX
If you feel uncomfortable using commandline tools, I would recommend that
you try
TortoiseSVN, which is an Explorer extension.
http://tortoisesvn.tigris.org/
That way, you can check out, or update simply by right clicking on the
folder in Explorer.
Using this approach, you only need the URL of the repository, which can be
found on the osgeo website under "Subversion".
FDO: https://fdo.osgeo.org/svn/fdo/trunk
MapGuide: https://mapguide.osgeo.org/svn/mapguide/trunk
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060915/d01043c0/attachment.html
More information about the Mapguide-users
