[mapguide-users] POOL:DWF or AJAX
Ivan Miličević ivan at ineo.hr
Fri Sep 15 11:54:00 EDT 2006
Jason, you're a God!
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 15. rujan 2006 17:50
Subject: RE: [mapguide-users] POOL:DWF or AJAX
Yes, that's correct.  The SET is the commandline way of creating Windows
EVs, but they only stay around for the current session if you set them at
the command line (I think).
Here's what I have:
FDO=D:\OSGeo\FDOBuild\fdo
FDOBUILD=D:\OSGeo\FDOBuild
FDOMYSQL=C:\Program Files\MySQL\MySQL Server 5.0
FDOTHIRDPARTY=D:\OSGeo\FDOBuild\Thirdparty
FDOUTILITIES=D:\OSGeo\FDOBuild\Utilities
FDO_SVN_ROOT=D:\OSGeo\FDODev
GDAL_DATA=D:\OSGeo\MGBuild\Oem\gdal-1.3.0\data
MGBUILD=D:\OSGeo\MGBuild
NLSDIR=D:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c\Src\xalanc\NLS
PROJ_LIB=D:\OSGeo\MGBuild\Oem\proj-4.4.9\nad
XALANROOT=D:\OSGeo\FDOBuild\Thirdparty\apache\xml-xalan\c
XERCESCROOT=D:\OSGeo\FDOBuild\Thirdparty\apache\xml-xerces\c
You have to be careful though, because if you have the GDAL and PROJ
variables set (required for the MapGuide build) I think it messes up the FDO
build.  It's probably best to set these at the command line.  What I do,
however, is something like this:
SET OLD_GDAL_DATA=%GDAL_DATA%
SET GDAL_DATA=
SET OLD_PROJ_LIB=%PROJ_LIB%
SET PROJ_LIB=
pushd %FDOBUILD%
call build.bat
popd
SET GDAL_DATA=%OLD_GDAL_DATA%
SET OLD_GDAL_DATA=
SET PROJ_LIB=%OLD_PROJ_LIB%
SET OLD_PROJ_LIB=
Jason
Sent: Friday, September 15, 2006 08:37
Ok, thanks!!!
And just one more thing...
3. Ensure that the Windows Environment Variables are set as follows:
        SET FDO=[FDO OpenSource]\Fdo
        SET FDOUTILITIES=[FDO OpenSource]\Utilities
        SET FDOTHIRDPARTY=[FDO OpenSource]\ThirdParty
        SET XALANROOT=%FDOTHIRDPARTY%\apache\xml-xalan\c
        SET XERCESCROOT=%FDOTHIRDPARTY%\apache\xml-xerces\c
        SET NLSDIR=%XALANROOT%\Src\xalanc\NLS
Q: What is variable and what is value? For example? Is FDO variable and [FDO
OpenSource]\Fdo value? Is that correct?
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
