[mapguide-users] Deleting Feature Data Problems
Tom Fukushima tom.fukushima at autodesk.com
Wed Sep 20 13:14:47 EDT 2006
Hi Adam,
I'd like to look into this problem a little more.
Could you send me the XML and data file of the feature source that you
are trying to delete features from?  If you have Studio you can open the
feature source and do a "File > Save As XML" to get the XML; and use the
"Data files" control to download the data file .
Also, which OS are you running the server on?
Thanks
Tom
  _____
From: Adam Herbert [mailto:adam at aemsaustralia.com.au]
Sent: Tuesday, September 19, 2006 5:09 PM
Subject: RE: [mapguide-users] Deleting Feature Data Problems
Hi Tom,
Thanks for letting me know.
  _____
From: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Sent: Wednesday, 20 September 2006 8:57 AM
Hi Adam,
1.01.17812 is compiled against FDO R050 so the bug would still be in
that version.
Regard,
Tom
  _____
Sent: Tuesday, September 19, 2006 4:51 PM
OK, This might be a dumb question but does that mean it's supposed to be
fixed in 1.01.17812?
  _____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Wednesday, 20 September 2006 8:25 AM
Adam,
This is a known bug with the FDO R050 that was released with the
MapGuide 1.0 release.
Bruce
  _____
Sent: September 18, 2006 11:36 PM
Subject: [mapguide-users] Deleting Feature Data Problems
I am not sure if this is a bug or my error but when I try to use:
Dim deleteFilter As String = "PRIMARYINDEX = " & objectId
actionCommands.Add(New MgDeleteFeatures("actions", deleteFilter))
' Execute the "delete" commands
featureService.UpdateFeatures(resourceIdentifier, actionCommands, False)
My MgServer service dies and I have to restart it. Also the feature is
not deleted from the feature source.
I am successfully using MgInsertFeatures against this feature source so
I don't think it is a permissions issue. Anyway any ideas would be
greatly appreciated.
Regards,
Adam Herbert
IT Manager
AEM Solutions Pty Ltd
PO Box 514, Toowoomba Q. 4350
Phone: 07 4613 0455
Cell: 0437 599 907
Website: www.aemsaustralia.com.au <http://www.aemsaustralia.com.au>
Important Disclaimer and Warning
AEMS does not represent or warrant that any attached files are free from
computer viruses or other defects. The attached files are provided, and
may only be used, on the basis that the user assumes all responsibility
for any loss, damage or consequences resulting directly or indirectly
from use of the attached files. The liability of AEMS in any event is
limited to either the re-supply of the attached files or the cost of
having the attached files re-supplied.
NOTE: The views expressed by the individual in this message do not
necessarily reflect those of the organisation.
AEMS is committed to protecting the privacy of individuals, and is bound
by the principles of the Commonwealth Privacy Act (1988).
The information contained in this message is confidential and may be
legally privileged. The message is intended solely for the addressee(s).
If you are not the intended recipient, you are hereby notified that any
use, dissemination, or reproduction is strictly prohibited and may be
unlawful. If you are not the intended recipient, please contact the
sender by return e-mail and destroy all copies of the original message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060920/356ac5a6/attachment.html
More information about the Mapguide-users mailing list
