Unable to select some features on map
Marco Spiga
marcospiga at hotmail.com
Sat Sep 23 20:06:46 EDT 2006
Hello everybody, i hope my english is clear enough...
I encountered the following problem.
I created a layer using a shp file as datasource. I have no problems when
selecting with the mouse the items displayed in the preview. I assume that
because the one selected becomes blue.
Then i created a map and associated that layer to the map. After setting
Initial View coordinates i am able to see the layer displayed in the
preview.
The problem is that this time i am NOT able to do any mouse selection.
I can zoom and pan but not select.
I then repeated the same procedure with an sdf file from Sheboygan sample. I
had NO problems this time being able to select in the map preview.
Then i imported the same shp file into MapGuide Studio and used the sdf file
it created (i just copyed it from the Resources folder) again in webstudio.
Still i cannot select items.
(Same happens in MapGuide Studio).
Is there anything wrong with my file? Am i missing a setting somewhere?
Check "Features on the layer can be selected" is selected.
I would really appreciate any help. Thank you.
View this message in context: http://www.nabble.com/Unable-to-select-some-features-on-map-tf2324802.html#a6467914
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide-users
