[mapguide-users] Re: ODBC in Webstudio
Antonio de la Pe?a antonio_dlp at dsgmexico.com.mx
Tue Sep 26 10:26:26 EDT 2006
Thank you, Zak.
That's the way I'm using it now: configuring non SHP or SDF feature sources
with MapGuide Author. I'll try and dig in the Webstudio code to see what can
I figure out about editing other feature sources from it. Would you know how
to do it by hand as a first step?
Zak James wrote:
> Antonio,
> I meant to mention that if you configure a feature source and layer
> for an odbc source using Autodesk Studio or the mapagent utility, you
> can add it to maps in webstudio and it will display in a map preview.
> The same should apply to any unsupported provider type. Obviously,
> direct support would be a big improvement!
> zak
> On 9/26/06, Zak James <zak4ms at gmail.com> wrote:
>> Antonio,
>> That's not currently possible but could be added relatively easily.
>> zak
>> On 9/25/06, Antonio de la Pe?a <antonio_dlp at dsgmexico.com.mx> wrote:
>> > Is there a way to configure ODBC features using Webstudio? Currently I
>> can
>> > only see SDF and SHP datatypes in the FeatureSource configuration
>> panels.
>> > View this message in context:
>> http://www.nabble.com/ODBC-in-Webstudio-tf2335872.html#a6499242
>> > Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> > For additional commands, e-mail: users-help at mapguide.osgeo.org
>> Zak James
>> Applications and Software Development
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
> Zak James
View this message in context: http://www.nabble.com/ODBC-in-Webstudio-tf2335872.html#a6508008
More information about the Mapguide-users mailing list
