[mapguide-users] RE: Advantages of storing spatial data in SQL
	Server
    kalpesh
    kalpesh at pie-solution.com
    Sun Apr  1 23:34:12 EDT 2007
When you say data which needs to be edited, are you talking about the
digitizing functions ? I believe, there are functions right now which allow
you to edit data stored in the repository, isnt it ?
As far as manageability is concerned, we can take backups of packages as a
single file from MapGuide Administrator mode just like SQL Server.
Please correct me if I am wrong.
JasonBirch wrote:
> Also, decreases performance when compared to SDF.  SDF stores geometry in
> FGF-native format, so doesn't need to be converted on the fly.
> To balance server resources with flexibility, I'm using SDF for data that
> I do not need to edit via the web or see changes to on the fly, and RDBMS
> for anything else.
> If I was looking at 100% integration with other corporate apps, or didn't
> have access to FME for regenerating the SDFs (including the generalized
> versions) nightly, RDBMS would win out because of its manageability.  I'd
> give up a certain amount of performance for ease of management any day.
> Although SDFs are loosely based on SQLite, they do not provide the
> benefits of views, multiple attribute indexes (I think?) multi-user
> concurrent editing, and other DB-like features.
> Jason
> ________________________________
> From: Warren Medernach
> Subject: RE: [mapguide-users] Advantages of storing spatial data in SQL
> Server
> The advantages are many...
> - Data in a single location reduces redundancy
> - Easier maintenance (backing up a single database vs. multiple files
> scattered around)
> - Security standards for data access can be established and enforced
> - A DBMS is better suited to managing large numbers of concurrent users.
> Disadvantages...
> - Higher cost with respect to aquiring and maintaining
> - Adds complexity, escpecially in smaller projects
> By no means is this a complete list...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Advantages-of-storing-spatial-data-in-SQL-Server-tf3496205s16610.html#a9784764
