SV: [mapguide-users] arcgis does not show wfs/wms
Bjurström Jan Jan.Bjurstrom at lm.se
Mon Apr 2 02:51:12 EDT 2007
Hello there, Batul
I have tried wms from MGOS and connected these services from Mapinfo 7.5 and 8.5 and ArcGIS 9.1.
If you don't see(find) the service, maybe you are using wrong URL.
http://servername:<portno>/mapguide/mapagent/mapagent.fcgi?REQUEST=GetCapabilities&SERVICE=WMS&FORMAT=text/xml
Once connected you will probably get it opened in the default coordinate system (EPSG:4326) even if you configured the MGOS WMS to distribute it in another coordinate system. Change this manually with a right-click in the TOC in ArcMAP.
Which you better luck!
Janne
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Batul
Skickat: den 30 mars 2007 12:20
Till: mapguide-users at lists.osgeo.org
Ämne: [mapguide-users] arcgis does not show wfs/wms
i have a BIG problem. my team and me, we try to build gdi test platform. we chose autodesk mapguide open source for the software soulution. my problem is now, that i cant see the wfs/wms data in arcgis... how can i solve this problem???
regards,
Batul
View this message in context: http://www.nabble.com/arcgis-does-not-show-wfs-wms-tf3491343s16610.html#a9750530
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
