[mapguide-users] MapGuide Java with Apache and SSL setup and configuration
Dhirendra Kumar dhirendra.mgos at gmail.com
Tue Apr 3 03:22:29 EDT 2007
Hi Scott Reisdorf,
Why are you woring about configuration of httpd.conf and ssl.conf ? During
WebServerExtension, If you will chose Bundled Configuration then it will
configured every thing Automatically. Try to install MapGuide version 1.1.0.
Regards,
Dhirendra Kumar
Scott Reisdorf wrote:
> Anyone successfully get Mapguide with Apache/Tomcat and SSL configured?
> If so do you think you can post some sample httpd.conf and ssl.conf
> configurations you used to get it up and running.  I am having a tough
> time getting the Tomcat and Apache configured to use SSL while
> connecting to the Mapguide Repo.
> Thanks,
> Scott Reisdorf
> reisdorf1 at llnl.gob
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MapGuide-Java-with-Apache-and-SSL-setup-and-configuration-tf3507349s16610.html#a9804860
