[mapguide-users] MapGuide Java with Apache and SSL setup and configuration
Scott Reisdorf reisdorf1 at llnl.gov
Tue Apr 3 11:01:16 EDT 2007
Out of the box, MGOS does not support SSL with Apache/Tomcat.  The httpd
files need to be modified to add the SSL configuration.
I have done this, but using IE 6 I get the msg saying This page has both
Secure and Unsecure data, even though I am going through Apache with the
SSL certificate.
Going through the code I think it has to do with how the templates are
coded and how each access the different frames.
Anyone else try to get SSL working with MGOS and get it to work with IE
6 where it doesnt show the popup saying Both Secure and non secure data
exist do you wish to show the unsecure data?
Again any help or insight is appreciated.
-scott
Dhirendra Kumar wrote:
> Hi Scott Reisdorf,
> Why are you woring about configuration of httpd.conf and ssl.conf ? During
> WebServerExtension, If you will chose Bundled Configuration then it will
> configured every thing Automatically. Try to install MapGuide version 1.1.0.
> Regards,
> Dhirendra Kumar
> Scott Reisdorf wrote:
>> Anyone successfully get Mapguide with Apache/Tomcat and SSL configured?
>> If so do you think you can post some sample httpd.conf and ssl.conf
>> configurations you used to get it up and running.  I am having a tough
>> time getting the Tomcat and Apache configured to use SSL while
>> connecting to the Mapguide Repo.
>> Thanks,
>> Scott Reisdorf
>> reisdorf1 at llnl.gob
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070403/a1405e05/attachment.html
