[mapguide-users] MapGuide Java with Apache and SSL setup and
configuration
Scott Reisdorf
reisdorf1 at llnl.gov
Tue Apr 3 11:23:41 EDT 2007
I found the problem. I think this should be included in the next release.
There are 3 places were Frames or IFrames are used with out a 'SRC' element
ajaxmappane.templ - InitContextMenu() and InitToolbarFlyouts()
framesettaskbar.templ - <frame name="scriptFrame
framesetnotaskbar.templ - <frame name="scriptFrame
Without the src element, using https IE shows the following message
This page contains both secure and nonsecure items.
More info on the message can be found here:
http://support.microsoft.com/default.aspx?scid=kb;en-us;261188
-scott
Scott Reisdorf wrote:
> Out of the box, MGOS does not support SSL with Apache/Tomcat. The
> httpd files need to be modified to add the SSL configuration.
> I have done this, but using IE 6 I get the msg saying This page has
> both Secure and Unsecure data, even though I am going through Apache
> with the SSL certificate.
> Going through the code I think it has to do with how the templates are
> coded and how each access the different frames.
> Anyone else try to get SSL working with MGOS and get it to work with
> IE 6 where it doesnt show the popup saying Both Secure and non secure
> data exist do you wish to show the unsecure data?
> Again any help or insight is appreciated.
> -scott
> Dhirendra Kumar wrote:
>> Hi Scott Reisdorf,
>> Why are you woring about configuration of httpd.conf and ssl.conf ? During
>> WebServerExtension, If you will chose Bundled Configuration then it will
>> configured every thing Automatically. Try to install MapGuide version 1.1.0.
>> Regards,
>> Dhirendra Kumar
>>> Anyone successfully get Mapguide with Apache/Tomcat and SSL configured?
>>> If so do you think you can post some sample httpd.conf and ssl.conf
>>> configurations you used to get it up and running. I am having a tough
>>> time getting the Tomcat and Apache configured to use SSL while
>>> connecting to the Mapguide Repo.
>>> Thanks,
>>> Scott Reisdorf
>>> reisdorf1 at llnl.gob
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070403/6e62d2fd/attachment.html
