[mapguide-users] OGR- Postgre+postgis work???
Traian Stanev
traian.stanev at autodesk.com
Tue Apr 3 11:10:19 EDT 2007
Hi.
Which version of MapGuide are you using? What is the file date of your OGRProvider.dll?
Once you put the provider dll in the Server/Bin/FDO and add it to providers.xml, you should be able to see the provider listed in the New Data Connection dialog. If you do not, it is likely that the provider dll is incompatible with your FDO dll. Please run a tool like depends.exe to see if there are any dependency problems with the OGRProvider.dll.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MapasCatastro
Sent: Tuesday, April 03, 2007 7:57 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] OGR- Postgre+postgis work???
hi, sorry for my english.
i download a OGRProvider.dll, modify a providers.xml, in directory the
server of mapguideos /fdo.
In studio (autodesk) i try to create a data conection but dont showme the
way to create a connection only showme $1000 / $30000 etc. what is this??
dont showme the form to conect, by user name or password etc to connect
postgre.
you can help to cretate this connection
is fine this?
1)download ogrprovider.dll
2)copy .dll into dir MapGuideOpenSource\Server\Bin\FDO
3)modify providers.xml
restart
thanks a lot
oscar
La Plata, Argentina.
macieksk wrote:
> MapasCatastro napisał(a):
>> Hi i try to connect my data base in postgis to mapguide studio, i modify
>> the
>> providers.xml and copy OGRProvider.dll, but in studio dont showme anythig
>> to
>> create a connection.
> can you send a url do screen of this error. i must see what it is...one
> time i have this same problem i thing...did you try reload mg server?
>> works mapguide os whit postgres + postgis to draw maps in ajax viewer??
> yes it works :) i use this in my project.
>> works in odbc conection whit postgres to draw maps in ajax viewer??
> i don't try this...
> Maciej Skórczewski
> mapguide-users mailing list
View this message in context: http://www.nabble.com/OGR--Postgre%2Bpostgis-work----tf3508543s16610.html#a9808719
