[mapguide-users] RE: OGR- Postgre+postgis work???
Traian Stanev traian.stanev at autodesk.com
Tue Apr 3 13:03:59 EDT 2007
The latest posted release is at:
http://download.osgeo.org/fdo/3.2.0/
Note that this is compiled against FDO 3.2 and will not work against 3.3.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MapasCatastro
Sent: Tuesday, April 03, 2007 12:29 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: OGR- Postgre+postgis work???
hi, thks for the help,
 wheare is the last or work OGRProvider.dll to download????
plese post the link
thanks a lot
oscar
Traian Stanev wrote:
> Hi.
> Which version of MapGuide are you using? What is the file date of your
> OGRProvider.dll?
> Once you put the provider dll in the Server/Bin/FDO and add it to
> providers.xml, you should be able to see the provider listed in the New
> Data Connection dialog. If you do not, it is likely that the provider dll
> is incompatible with your FDO dll. Please run a tool like depends.exe to
> see if there are any dependency problems with the OGRProvider.dll.
> Traian
> Sent: Tuesday, April 03, 2007 7:57 AM
> Subject: Re: [mapguide-users] OGR- Postgre+postgis work???
> hi, sorry for my english.
> i download a OGRProvider.dll, modify a providers.xml, in directory the
> server of mapguideos /fdo.
> In studio (autodesk) i try to create a data conection but dont showme the
> way to create a connection only showme $1000 / $30000 etc. what is this??
> dont showme the form to conect, by user name or password etc to connect
> postgre.
> you can help to cretate this connection
> is fine this?
> 1)download ogrprovider.dll
> 2)copy .dll into dir MapGuideOpenSource\Server\Bin\FDO
> 3)modify providers.xml
> restart
> thanks a lot
> oscar
> La Plata, Argentina.
> macieksk wrote:
>> MapasCatastro napisał(a):
>>> Hi i try to connect my data base in postgis to mapguide studio, i modify
>>> the
>>> providers.xml and copy OGRProvider.dll, but in studio dont showme
>>> anythig
>>> to
>>> create a connection.
>> can you send a url do screen of this error. i must see what it is...one
>> time i have this same problem i thing...did you try reload mg server?
>>> works mapguide os whit postgres + postgis to draw maps in ajax viewer??
>> yes it works :) i use this in my project.
>>> works in odbc conection whit postgres to draw maps in ajax viewer??
>> i don't try this...
>> Maciej Skórczewski
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/OGR--Postgre%2Bpostgis-work----tf3508543s16610.html#a9808719
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/OGR--Postgre%2Bpostgis-work----tf3508543s16610.html#a9817722
