[mapguide-users] RE: RE: OGR- Postgre+postgis work???
MapasCatastro mapas at laplata.gov.ar
Tue Apr 3 17:46:15 EDT 2007
thanks now works!!!!!
and very fine!!!!
thanks Traian
Traian Stanev wrote:
> The latest posted release is at:
> http://download.osgeo.org/fdo/3.2.0/
> Note that this is compiled against FDO 3.2 and will not work against 3.3.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MapasCatastro
> Sent: Tuesday, April 03, 2007 12:29 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: OGR- Postgre+postgis work???
> hi, thks for the help,
>  wheare is the last or work OGRProvider.dll to download????
> plese post the link
> thanks a lot
> oscar
>> Hi.
>> Which version of MapGuide are you using? What is the file date of your
>> OGRProvider.dll?
>> Once you put the provider dll in the Server/Bin/FDO and add it to
>> providers.xml, you should be able to see the provider listed in the New
>> Data Connection dialog. If you do not, it is likely that the provider dll
>> is incompatible with your FDO dll. Please run a tool like depends.exe to
>> see if there are any dependency problems with the OGRProvider.dll.
>> Traian
>> MapasCatastro
>> Sent: Tuesday, April 03, 2007 7:57 AM
>> Subject: Re: [mapguide-users] OGR- Postgre+postgis work???
>> hi, sorry for my english.
>> i download a OGRProvider.dll, modify a providers.xml, in directory the
>> server of mapguideos /fdo.
>> In studio (autodesk) i try to create a data conection but dont showme the
>> way to create a connection only showme $1000 / $30000 etc. what is this??
>> dont showme the form to conect, by user name or password etc to connect
>> postgre.
>> you can help to cretate this connection
>> is fine this?
>> 1)download ogrprovider.dll
>> 2)copy .dll into dir MapGuideOpenSource\Server\Bin\FDO
>> 3)modify providers.xml
>> restart
>> thanks a lot
>> oscar
>> La Plata, Argentina.
>> macieksk wrote:
>>> MapasCatastro napisał(a):
>>>> Hi i try to connect my data base in postgis to mapguide studio, i
>>>> modify
>>>> the
>>>> providers.xml and copy OGRProvider.dll, but in studio dont showme
>>>> anythig
>>>> to
>>>> create a connection.
>>> can you send a url do screen of this error. i must see what it is...one
>>> time i have this same problem i thing...did you try reload mg server?
>>>> works mapguide os whit postgres + postgis to draw maps in ajax viewer??
>>> yes it works :) i use this in my project.
>>>> works in odbc conection whit postgres to draw maps in ajax viewer??
>>> i don't try this...
>>> Maciej Skórczewski
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/OGR--Postgre%2Bpostgis-work----tf3508543s16610.html#a9808719
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://www.nabble.com/OGR--Postgre%2Bpostgis-work----tf3508543s16610.html#a9817722
View this message in context: http://www.nabble.com/OGR--Postgre%2Bpostgis-work----tf3508543s16610.html#a9826973
