[mapguide-users] webstudio expected behavior
Paul Spencer pagameba at gmail.com
Mon Apr 9 15:05:01 EDT 2007
Brad,
Web Studio currently only supports creating/editing feature sources
of type SDF and SHP.
Cheers
Paul
On 9-Apr-07, at 10:29 AM, Brad Nesom wrote:
> What is expected behavior in webstudio? I am running 1.2 beta.
> I go to webstudio and select the library and then the resource name
> which I assume you cannot assign permissions in webstudio but I
> have done so in the AD Studio preview(25 days left) I get one
> drilldown and double click on one layer name (which opens it in the
> open resources pane. But, then the resource name in site explorer
> is compressed and there is only a minus sign there. A double click
> on it renders nothing. I cannot open other layer files within that
> resource. Also, when I select that resource I get an unsupported
> resource pane at the bottom that says… MapGuide Open Source Web
> Studio does not support editing of this resource. This is an
> osgeo.arcsde.3.2 provider.
> The Sheboygan samples I can drill down all day long and open those
> layers.
> I just closed the site and re-opened it. And after adding several
> sample layers and layouts to open resources, I went to my roads
> layer in my production connection. This layer is quite large, it is
> an ArcSDE layer in oracle 10gR2.0.5. I see the feature source,
> connection and listing of fields and properties to display in the
> settings pane at the top. There are no scale ranges so that is
> empty but then I get … Resource was not found: Session:f02df2fe-
> ffff-ffff-8000-00065b69fe5a_eng_C0A86FC40AFC0AFB0AFA//Production/
> ACOG/Layers/Roads.LayerDefinition Exception occurred in method
> MgResourceDefinitionManager.GetDocument at line 476 in file c:
> \build_bond_area\mapguide_open_source_v1.2\build_8.3\mgdev\server
> \src\services\resource\ResourceDefinitionManager.cpp
> In the bottom preview pane.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
