[mapguide-users] Zoomtoview doesn't work in some browsers
Chris Claydon
chris.claydon at autodesk.com
Tue Apr 10 11:54:04 EDT 2007
Do you see the same problem in IE and Firefox?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: April 10, 2007 9:50 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Zoomtoview doesn't work in some browsers
Not sure if session has expired but in the browser and in adesk studio
you
can zoom several times as long as you don't go do something else. Then
when
you return to zoom it doesn't work. I studio by going to another
resource
and back again it seems to refresh because then you have another set of
zooms you can do.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Claydon
Sent: Tuesday, April 10, 2007 10:40 AM
To: MapGuide Users Mail List
If your session has expired then the map fails to redraw after a mouse
wheel zoom. In IE, an error message is displayed, but in Firefox no
indication is given that something went wrong. Is this the behavior
you're seeing?
Sent: April 9, 2007 10:34 AM
Is this the same or related problem I see in ie (mgos1.2beta) where
using
the zoom wheel mouse function it doesn't always -redraw the map?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of gorank
Sent: Monday, April 09, 2007 2:55 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Zoomtoview doesn't work in some browsers
In mozilla firefox function zoomtoview works fine, also in IE 7.0 beta
3. On
some version IE does not work: on first event it's zooming, but on
second
event it's not zooming.
Javascript code:
function zoom_sel(X1,Y1,M1,selekcija)
parent.parent.SetSelectionXML(selekcija);
parent.parent.ZoomToView(X1,Y1,M1,true);
View this message in context:
http://www.nabble.com/Zoomtoview-doesn%E2%80%99t-work-in-some-browsers-t
f354
6172s16610.html#a9899378
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
