[mapguide-users] Zoomtoview doesn't work in some browsers
Chris Claydon
chris.claydon at autodesk.com
Tue Apr 10 12:09:20 EDT 2007
Hi Brad,
I just spent some time playing around with IE, Firefox and Studio, and
this is what I see:
Firefox behaves well - if I switch to another application and switch
back, it still processes my mouse wheel events.
IE (and hence Studio, which embeds an IE browser) - when I switch to
another application, or to another tab in Studio, or just switch the
focus to the URL address field in IE, I stop receiving mouse wheel
events from the map. If I click on the map, it doesn't help, but if I
click on the map's toolbar, properties pane, legend, or task pane, the
mouse wheel starts working again.
Are these observations consistent with what you're seeing?
Thanks,
Chris.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Claydon
Sent: April 10, 2007 9:54 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Zoomtoview doesn't work in some browsers
Do you see the same problem in IE and Firefox?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: April 10, 2007 9:50 AM
To: 'MapGuide Users Mail List'
Not sure if session has expired but in the browser and in adesk studio
you
can zoom several times as long as you don't go do something else. Then
when
you return to zoom it doesn't work. I studio by going to another
resource
and back again it seems to refresh because then you have another set of
zooms you can do.
Claydon
Sent: Tuesday, April 10, 2007 10:40 AM
If your session has expired then the map fails to redraw after a mouse
wheel zoom. In IE, an error message is displayed, but in Firefox no
indication is given that something went wrong. Is this the behavior
you're seeing?
Sent: April 9, 2007 10:34 AM
Is this the same or related problem I see in ie (mgos1.2beta) where
using
the zoom wheel mouse function it doesn't always -redraw the map?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of gorank
Sent: Monday, April 09, 2007 2:55 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Zoomtoview doesn't work in some browsers
In mozilla firefox function zoomtoview works fine, also in IE 7.0 beta
3. On
some version IE does not work: on first event it's zooming, but on
second
event it's not zooming.
Javascript code:
function zoom_sel(X1,Y1,M1,selekcija)
parent.parent.SetSelectionXML(selekcija);
parent.parent.ZoomToView(X1,Y1,M1,true);
View this message in context:
http://www.nabble.com/Zoomtoview-doesn%E2%80%99t-work-in-some-browsers-t
f354
6172s16610.html#a9899378
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
