[mapguide-users] web studio - feature data setup?
deepdivetc
ttc at GoColumbiaMO.com
Tue Apr 10 16:05:56 EDT 2007
Hi all,
I was wondering if there was any new solution to this. I know that this was
a older thread, but doing searches I came across this and I am having the
exact same issue and this thread just kind of ended. Through more searching
I have not found anymore on the subject and would love to know if there was
an anwser or a fix, sorry if it was posted and I missed it and cant find it.
Thank you
Tim Carr
TW wrote:
> Zak
> The uploaded file is not corrupt it still can be opened. Its almost as if
> webstudio will not attempt to load the data source when creating the
> layer. I noticed that when I select the data source, the animated icon on
> the viewer frame doesn't do anything.
> I know that when I initially load the webstudio I am getting some page
> errors.
> If you want me to submit the feature xml, you will have to explain where I
> can get this file for you. I am not sure I know where in the webstudio I
> have to save this xml file.
> Tim
> Zak James wrote:
>> Tim,
>> It's possible that something specific to IIS is going wrong, but if
>> that was the case I would expect the sdf/shp in the repository to be
>> damaged in some way. Can you grab a shape file from the repository and
>> try to load it with another tool to make sure it's still valid?
>> If that looks ok, I'd be interested in seeing the xml for the feature
>> source (you can save it using Studio or the mapagent utility.)
>> zak
>> On 1/29/07, TW <twiebe at cityofwinkler.ca> wrote:
>>> Zak,
>>> Yes, the sdf file and shp files are in the library respository folder on
>>> the
>>> server.
>>> However web studio will not allow me to create an unmanaged feature
>>> source.
>>> Any suggestions? Is there more setting up to do with IIS?
>>> Zak James wrote:
>>> > Tim,
>>> > Can you search through the repository to see if the sdf file is
>>> > actually present on the server? I'm wondering if there is some IIS
>>> > specific issue with the upload mechanism. It works under apache.
>>> > Another thing you could try is creating an unmanaged feature source
>>> > (pointing it to a file/folder already on the server) to see if that
>>> > allows you to create a layer.
>>> > zak
>>> > On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
>>> >> When I try to create a layer from an uploaded data source in web
>>> studio
>>> >> it
>>> >> will not allow me to occupy the feature class or geometry fields to
>>> setup
>>> >> the layer.
>>> >> Web studio will allow me to create a feature data source and upload
>>> >> either a
>>> >> shp file or sdf, and yes it does actual create a folder in the
>>> >> respoistory
>>> >> and makes it available.
>>> >> I am running the server on IIS 5. Am I missing something obvious? I
>>> have
>>> >> used the enterprise software and it works fine. But I cannot use the
>>> >> Opensource.
>>> >> What am I missing?
>>> >> Tim
>>> >> View this message in context:
>>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8657214
>>> >> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> >> _______________________________________________
>>> >> mapguide-users mailing list
>>> >> mapguide-users at lists.osgeo.org
>>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> > Zak James
>>> > Applications and Software Development
>>> > DM Solutions Group Inc.
>>> > http://www.dmsolutions.ca
>>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8690301
>> Zak James
> http://www.nabble.com/file/6112/error1.JPG error1.JPG
> http://www.nabble.com/file/6113/error2.JPG error2.JPG
View this message in context: http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a9927392
