[mapguide-users] web studio - feature data setup?
Dave McIlhagga
dmcilhagga at dmsolutions.ca
Tue Apr 10 21:11:42 EDT 2007
Hi Chris, and others,
Web Studio is a key component of our emerging commercial activities
with MapGuide. It was first developed by us as a means to get a
better understanding of the MapGuide architecture and to fill a hole
in the open source stack of technologies around MapGuide.
Since then, most of our development energy has been focused on Fusion
which some of you have heard about as an application development
framework around MapGuide. With this now maturing, we are planning to
balance out our development activities as we progressively work
towards providing a fully supported package of technologies for our
customers and growing list of partners.
What does this mean for Web Studio? Since it is a critical element
for DMSG -- we will certainly be returning more energies to it in the
not too distant future, and this will be reflected in future versions
of MGOS.
I hope that we can soon provide a development roadmap to the
community that will reflect our plans for Web Studio. Of course we
would welcome contributors and input re. the needs from the technology.
Thanks,
Dave
Dave McIlhagga
President & CEO
DM Solutions Group (DMSG)
www.dmsolutions.ca
p: 613-565-5056 x15
f: 613-565-0925
On 10-Apr-07, at 4:13 PM, Chris Gountanis wrote:
> I am curious as well. What is the future for WebStudio? Are they
> waiting for
> some open source crew to pick it up and complete it? I have yet
> been able to
> use it for anything. Studio Enterprise along with its API is
> great... don't
> get me wrong. I am sure Autodesk would rather have us buy Studio
> Enterprise
> but it would be nice to know what the future will be for the web
> studio.
> Chris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> deepdivetc
> Sent: Tuesday, April 10, 2007 3:06 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] web studio - feature data setup?
> Hi all,
> I was wondering if there was any new solution to this. I know that
> this was
> a older thread, but doing searches I came across this and I am
> having the
> exact same issue and this thread just kind of ended. Through more
> searching
> I have not found anymore on the subject and would love to know if
> there was
> an anwser or a fix, sorry if it was posted and I missed it and cant
> find it.
> Thank you
> Tim Carr
> TW wrote:
>> Zak
>> The uploaded file is not corrupt it still can be opened. Its
>> almost as if
>> webstudio will not attempt to load the data source when creating the
>> layer. I noticed that when I select the data source, the animated
>> icon on
>> the viewer frame doesn't do anything.
>> I know that when I initially load the webstudio I am getting some
>> page
>> errors.
>> If you want me to submit the feature xml, you will have to explain
>> where I
>> can get this file for you. I am not sure I know where in the
>> webstudio I
>> have to save this xml file.
>> Tim
>> Zak James wrote:
>>> Tim,
>>> It's possible that something specific to IIS is going wrong, but if
>>> that was the case I would expect the sdf/shp in the repository to be
>>> damaged in some way. Can you grab a shape file from the
>>> repository and
>>> try to load it with another tool to make sure it's still valid?
>>> If that looks ok, I'd be interested in seeing the xml for the
>>> feature
>>> source (you can save it using Studio or the mapagent utility.)
>>> zak
>>> On 1/29/07, TW <twiebe at cityofwinkler.ca> wrote:
>>>> Zak,
>>>> Yes, the sdf file and shp files are in the library respository
>>>> folder on
>>>> the
>>>> server.
>>>> However web studio will not allow me to create an unmanaged feature
>>>> source.
>>>> Any suggestions? Is there more setting up to do with IIS?
>>>> Zak James wrote:
>>>>> Tim,
>>>>> Can you search through the repository to see if the sdf file is
>>>>> actually present on the server? I'm wondering if there is some IIS
>>>>> specific issue with the upload mechanism. It works under apache.
>>>>> Another thing you could try is creating an unmanaged feature
>>>>> source
>>>>> (pointing it to a file/folder already on the server) to see if
>>>>> that
>>>>> allows you to create a layer.
>>>>> zak
>>>>> On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
>>>>>> When I try to create a layer from an uploaded data source in web
>>>> studio
>>>>>> it
>>>>>> will not allow me to occupy the feature class or geometry
>>>>>> fields to
>>>> setup
>>>>>> the layer.
>>>>>> Web studio will allow me to create a feature data source and
>>>>>> upload
>>>>>> either a
>>>>>> shp file or sdf, and yes it does actual create a folder in the
>>>>>> respoistory
>>>>>> and makes it available.
>>>>>> I am running the server on IIS 5. Am I missing something
>>>>>> obvious? I
>>>> have
>>>>>> used the enterprise software and it works fine. But I cannot
>>>>>> use the
>>>>>> Opensource.
>>>>>> What am I missing?
>>>>>> Tim
>>>>>> View this message in context:
> http://www.nabble.com/web-studio---feature-data-setup--
> tf3124673s16610.html#
> a8657214
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Zak James
>>>>> Applications and Software Development
>>>>> DM Solutions Group Inc.
>>>>> http://www.dmsolutions.ca
> a8690301
>>> Zak James
>> http://www.nabble.com/file/6112/error1.JPG error1.JPG
>> http://www.nabble.com/file/6113/error2.JPG error2.JPG
> a9927392
