[mapguide-users] trying to understand
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Apr 12 15:42:01 EDT 2007
In IIS, make sure sure that your site's bound to the right IP....maybe
it's only listening on your internal ip. The only other thing that I can
think of is to check that your domain name's pointing to the proper ip.
You said that you can ping both, but only the ip works.....when you ping
the name, does it show you that same ip? You could also try a tracert to
help see what's going on there.
Andrew
Brad Nesom wrote:
> Thanks Brian,
>  I did turn off friendly error and my security is set to allow anonymous on
> IIS. I am at a loss. I have set my client internet security to low and added
> the site into the intranet sites. Nothing works
> Brad
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
> Sent: Thursday, April 12, 2007 12:55 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] trying to understand
> You can turn off "Show friendly http error messages" in IE and you may
> see the problem. It could be a security issue in IIS.  Check the
> security settings for the website in IIS.
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Thursday, April 12, 2007 1:14 PM
> To: 'MapGuide Users Mail List'
> I am not sure what is wrong. Because I can ping the url or the ip. And
> get
> responses.
> If I use the ip rather than the url I get the same thing in ie7...
> Exclamation internet explorer cannot display the webpage
> http://Webmap.com/default.htm  after creating a simple start page
> returns
> the same. I can't seem to access any iis service from anywhere but the
> machine it is installed on. ???
> I did have success finally with the username at the end of the url. I
> will
> try to embed it next.
> Thanks
> Brad
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
> Morsell
> Sent: Thursday, April 12, 2007 10:27 AM
> What happens if you try to access that machine via the IP address from
> the
> other client?  Do you get anything if you just enter the web root
> (http://webmap.com)?  If you don't want the user to have to enter user
> and
> password info, you can embed the web layout in another HTML page and
> pass
> that information programmatically similar to the sample applications or
> you
> can add &USERNAME=Anonymous&PASSWORD= to the end of any web layout URL.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> Sent: Thursday, April 12, 2007 6:47 AM
> Subject: [mapguide-users] trying to understand
> I now have a working mgos and 22 days left on my studio trial. I want to
> get
> to the next level so I can make some decisions.
> Running 1.2 beta, on xp with (IIS 5.1) ajax viewer and .net.
> When I start my browser  on the server machine I am presented with a
> login
> dialog. I am using administrator to login there. I have set in the host
> file
> the ip address to webmap.com. On another machine on my domain I have
> done
> the same. However when I use the same URL
> http://webmap.com/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fProd
> ucti
> on%2fACOG%2fLayouts%2fACOGAsp.WebLayout&LOCALE=en
> I get cannot display page in ie7.
> This is how I have always created an intranet before, am I missing
> something?
> Also I have read and attempted the thread previously to remove the login
> dialog box. Can someone tell me specifically what file in what folder
> and
> what line I am supposed to add the username password into?
> Thanks for the patience.
> Brad
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
